viper 5301/canmax400 install/03 accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124453
Printed Date: April 18, 2026 at 8:31 AM
Topic: viper 5301/canmax400 install/03 accord
Posted By: sectechie
Subject: viper 5301/canmax400 install/03 accord
Date Posted: November 14, 2010 at 7:39 PM
I am currently in the process of installing a Viper 5301 with a Canmax400 in my 2003 Accord 4 door V6. Since this unit comes programmed for manual transmission I had to program it for auto trans. After this step I tried to unlock/ lock the doors, but had no success. I do get confirmation on my keyfob but the doors don't lock/ unlock. The only thing I can think of is my Can Bus wire is wrong, every guide I found online says to use the first green connector above the fuse panel and pin location #4. Any help you guys/gals can provide would be greatly appreciated as my car i torn apart and I need to get to work tomorrow:)
If anyone is willing to talk to me over the phone I can either give you a number or I would be more than happy to call you. ( I will buy beer for knowledge)
Thanks so much for your time!!!!!!
Ed Holt
POB 210
Laplata, MD
Posted By: godd dan it
Date Posted: November 14, 2010 at 7:53 PM
Not to be an ***, but what made you use a Canmax400 for this car? Its easy enough to work on without it. Could have just bought a cheaper bypass, and wired up the rest directly to the car (door locks, tach....etc.)
Did you flash the Canmax for your vehicle? Or was it flashed already?
Date Posted: November 14, 2010 at 9:10 PM
godd dan it,
I was told that the canmax400 would make it an easier install which is why I got it.  I saw the guy flash it today when I bought it for a 03 Accord.
In the last hour I was able to make the car turn over, but I can't get it to start using the RS.  The locks still don't work, but i do
get a confirmation chiro pn my keyfob saying that the alarm is locking/unlocking.  I was thinkin it might be a D2D cable issue?
I tapped into the 1st green connector above the fuse panel on pin #4.  Do you have any ideas on what could be the issue?
Ed Holt
POB 210
Laplata, MD
Date Posted: November 14, 2010 at 9:24 PM
Did you hook up the grey/black wire, grey wire, violet/white wire from the Canmax? Just making sure you did this too. You are refering to the install guide right off Xpresskit right? https://www.xpresskit.com/VehicleCompatibility.aspx?p=-1&year=2003&make=Honda&model=Accord&ps=1&s=0 Its page 3.
Sometimes the D2D cables come broken or dont work correctly. You might need to W2W instead.
