python 460hp into 92 legend
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124472
Printed Date: March 18, 2026 at 12:10 PM
Topic: python 460hp into 92 legend
Posted By: zelsgt
Subject: python 460hp into 92 legend
Date Posted: November 15, 2010 at 8:08 PM
I had this alarm laying around and decided to install it since the factory keyless remotes are broken.
I would like to incorporate this aftermarket alarm with the factory alarm because it has a factory starter kill and i dont feel like wiring up a separate relay.
As for the trunk release and trunk pin, what two wires off the 460hp alarm do I use?
Posted By: zelsgt
Date Posted: November 15, 2010 at 8:29 PM
i found this thread. https://www.the12volt.com/installbay/forum_posts.asp?tid=521&DIR=P&fid=3
looks like the (-) wire is used. then what would i connect the (+) for door switch wire too?
Posted By: t&t tech
Date Posted: November 15, 2010 at 9:44 PM
You don't connect the positive trigger to anything, period, cut and isolate,
Posted By: zelsgt
Date Posted: November 16, 2010 at 1:00 AM
I read the reference guide wrong. When arming the python alarm, would this also arm the factory alarm? I would like to retain the factory ignition kill feature.
Posted By: zelsgt
Date Posted: November 17, 2010 at 8:46 PM
Would the factory alarm work alongside my python alarm? Such as, disarming and unlocking and vice versa?
If that is the case, would the factory ignition kill be functional without adding another relay?
