2009 ford focus remote starter info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124623
Printed Date: April 29, 2026 at 2:28 PM
Topic: 2009 ford focus remote starter info
Posted By: briangerrety
Subject: 2009 ford focus remote starter info
Date Posted: November 23, 2010 at 9:31 AM
I have two hopefully easy questions...
I am preparing to install a remote starter for a 2009 ford focus.  My first question, is the wiring the same as the 2008 ford focus?  If not, does anyone have a wiring schematic for the 2009's?
Thanks in advance for your help.
Thanks,
Brian
Posted By: kreg357
Date Posted: November 23, 2010 at 9:41 AM
2008 thru 2010 are the same.  Here is a link to Bulldog Security for their wire guide :   https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Date Posted: November 23, 2010 at 10:53 AM
Thanks a lot for the fast reply man! appreciate the info!
Thanks,
Brian
Posted By: degotee
Date Posted: December 11, 2010 at 2:47 PM
Im having problems with no power on an 09 ford focus, also what do I do with all the extra ignition wires?
Posted By: kreg357
Date Posted: December 11, 2010 at 3:30 PM
Not sure what you mean.  What type remote start?  What extra wires?
The +12v Battery constant wire ( Blue/Red ) in the ignition harness is thin gauge.  You should not connect the remote starts  power wires to that ignition harness wire.  There is a thick +12v constant wire going to the fuse box, use that to supply the remote start.
