alarm wiring diagram for 96 rover tomcat
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124661
Printed Date: April 29, 2026 at 3:51 PM
Topic: alarm wiring diagram for 96 rover tomcat
Posted By: kurt-kadin
Subject: alarm wiring diagram for 96 rover tomcat
Date Posted: November 25, 2010 at 7:44 PM
hi there
I really need someones help on how to install an alarm kit/remote start into my 1996 Rover Tomcat turbo.
Please contact me if you can help
thank you ------------- ozzy
Posted By: howie ll
Date Posted: November 26, 2010 at 2:53 AM
This isn't entry level especially getting at the locks. Could you confirm this is a 220 Coupe?
Where are you and what make/model alarm R/S are you installing?
There's no tech data around now but I could probably do most of it from memory.
Date Posted: November 26, 2010 at 3:59 AM
Hi thank you for your reply .Yea its a 220 coupe and its alarm model is PLC Alarm FM-V3 Two Way Page Remote Engine Start and i live in New Zealand.
thank you
------------- ozzy
Posted By: howie ll
Date Posted: November 26, 2010 at 4:16 AM
Assuming your vehicle is a manual trannie does this alarm R/S have a "manual transmission reservation mode", also since I've never heard of it does it have a tach sensing wire or does it sense oil pressure?
Could you let me know before we go any further?
Date Posted: January 02, 2011 at 4:14 AM
Hi there sorry for the late reply i was away overseas.
yes it is manual. i changed the alarm system to a different model '2010 STEEL MATE - REMOTE ENGINE START KIT'.
Yea it has manual mode. im not sure of the tach sensing wire though sorry.
thank you very much ------------- ozzy
Posted By: howie ll
Date Posted: January 02, 2011 at 4:33 AM
What are your specific problems, it must be 10 years since I worked on one of these.
Tach will be at the back of the rev counter.
Your lock and unlock will be orange and pink (may be other way round) motor wires coming from the alarm/immobiliser box above the fusebox or in centre console.
