96 chrysler town&country disarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12476
Printed Date: April 25, 2026 at 8:17 PM
Topic: 96 chrysler town&country disarm
Posted By: paulslush
Subject: 96 chrysler town&country disarm
Date Posted: April 20, 2003 at 9:11 PM
     I have installed a remote /start keyless entry on a 96 Town&Country van, all works fine but I can not get the factory alarm to disarm, It goes off when the car is started with the remote start. I have the door locks working properly they will arm and disarm the system,I did have to enable 3 second pulse to get system to disam when unlocking.  The problem is I have hooked up the factory disarm wire from the remote start module to the white /red disarm wire at the bcm module with a 680 ohm resistor and it still won't disarm. If I arm the system and ground the WHITE/ red wire through the resistor it will disarm, it almost seems that the remote start module is to fast for the factory system.The system is a Prostart 2300. Any help would be greatly appreciated. Thankyou Paul.
Paulslush99fordmastertech
Posted By: draasch
Date Posted: April 21, 2003 at 5:09 AM
this is the info that i have for that van...
* OEM Disarm Wire Is Same As Door Lock Wire. Chassis Ground Thru A 4020 Ohm Resistor Will Arm OEM Alarm. Chassis Ground Thru A 665 Ohm Resistor Will Disarm OEM Alarm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
