2008 saturn aura
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124767
Printed Date: March 22, 2026 at 4:29 PM
Topic: 2008 saturn aura
Posted By: skyknack79
Subject: 2008 saturn aura
Date Posted: December 01, 2010 at 11:24 PM
Hi Guys-
Can anyone help me out with a vehicle wiring diagram request? My goal is to install a Viper 5701 into a 2008 Saturn Aura. Any help would be appreciated!! Thanks!!
Posted By: i am an idiot
Date Posted: December 02, 2010 at 6:06 AM
Remote start info for the 4 door Hatchback. May or may not be the same on all 3 models.
posted_image Battery RED (+) FUSE BOX IN THE LEFT SIDE CARGO AREA, IN A WHITE 2-PIN PLUG
posted_image Ignition 1 BLACK (+) AT STEERING COLUMN MODULE (SCCM) PIN 2 OF 25-PIN PLUG
posted_image Accessory 1 BROWN / GREEN (+) AT STEERING COLUMN MODULE (SCCM) PIN 17 OF 25-PIN PLUG
posted_image Starter 1 BLACK/ RED (+) AT FUSEBOX UNDER HOOD, PIN 4 OF 47-PIN PLUG
posted_image Anti-Theft Type UNIVERSAL IMMOBILIZER
posted_image Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
posted_image Tachometer ANY UNCOMMON WIRE AT INECTOR
posted_image Speed Sense BLUE/BROWN (AC) DRIVERS KICK PANEL
posted_image Low Crr. Pk Lights GRAY/GREEN (-) HEADLIGHT SWITCH
posted_image Brake Lights BROWN / GRAY (+) AT SWITCH OR DRIVERS KICK PANEL
posted_image Reverse Lights WHITE/ BLACK (+) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 42 OF GREEN CONNECTOR
posted_image Horn BROWN / WHITE posted_image
posted_image Rear Defrost BROWN / WHITE
posted_image Heated Driver Seat BROWN / GRAY (+) AT SWITCH
posted_image Heated Passngr Seat BLACK / YELLOW (+) AT SWITCH
Date Posted: December 02, 2010 at 6:07 AM
Security info for the 4 door hatchback.
posted_image Domelight Super GRAY (-) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 7 OF BLUE CONNECTOR
posted_image LF Latch WHITE/ GRAY (-) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 44 OF BLUE CONNECTOR
posted_image RF Latch GRAY (-) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 27 OF BLUE CONNECTOR
posted_image LR Latch GRAY (-) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 28 OF BLUE CONNECTOR
posted_image RR Latch GRAY (-) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 29 OF BLUE CONNECTOR
posted_image Trunk Trigger BLACK/ BLUE (-) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 28 OF GREEN CONNECTOR
posted_image Hood Trigger BROWN / GREEN (-) FUSE BOX IN THE LEFT SIDE CARGO AREA, PIN 11 OF BLUE CONNECTOR
posted_image Alarm Disarm OEM REMOTE ONLY
posted_image Low Crr Pk Lights GRAY/GREEN (-) HEADLIGHT SWITCH
posted_image Data Bus GREEN DATA ODBII CONNECTOR, PIN 1
Date Posted: December 02, 2010 at 2:29 PM
Thank you.  Anybody else have something?
Date Posted: December 03, 2010 at 6:41 AM
