avital 4003 blue wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124914
Printed Date: March 21, 2026 at 1:39 PM
Topic: avital 4003 blue wire
Posted By: megatfauzi76
Subject: avital 4003 blue wire
Date Posted: December 08, 2010 at 7:02 PM
Hai,
Im planning to install Remote Start Add On Avital 4003. The problem, I need a constant -ve output before the remote start activate so that it can activate my IMMOBILIZER first before it start to turm on my Accesories and Cranking.
I saw one wire at the avital 4003 wiring diagram. Its a Blue (-) 200ma Status Output. Can i use this wire to activate my immobilzer or this wire only supply -ve output after it start to turn on my accesories?
Posted By: chev104275
Date Posted: December 08, 2010 at 7:19 PM
Status output is the correct wire to activate the bypass
Date Posted: December 08, 2010 at 10:32 PM
The sequence..
When I pulse the remote start...Blue Wire ( status output ) will supply -ve output....
A few mili second after that..autostart will activate..start my accesories than..cranking...am i rite?
Date Posted: December 09, 2010 at 5:11 AM
Status output first then the ing turns on then acc turns on    Then acc drops out and starter engages then acc comes back on
Date Posted: December 10, 2010 at 2:03 AM
Thank you for the information
