directfax 1094
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124974
Printed Date: March 24, 2026 at 8:30 AM
Topic: directfax 1094
Posted By: wojohowski
Subject: directfax 1094
Date Posted: December 11, 2010 at 10:05 AM
Hey guys. i have been searching and searching the forums and i need DirectFax 1094 for the GEM wake up on a 05 F350 with a 6.0 Diesel. all the links i have found come to an expired Directtech page. thanks for any help.
Posted By: ceasar326
Date Posted: December 11, 2010 at 11:21 AM
From look switch. Wire (A) Lock, Wire (B) Unlock, Door Latch (C).. Use a relay = Pin 86 to 12volt, Cut wire (C) and connect pin 30 to the cut wire (C) door side. Pin 87a to the other cut wire (C) gem module. Pin 85 tap to Unlock of aftermarket alarm. Then on unlock wire of the aftermarket alarm use a diod with the strip facing the tap 85 pin wire and the other side of the diod to wire (B) unlock. Aftermarket lock wire to wire (A).
Posted By: accordnut
Date Posted: December 13, 2010 at 5:20 AM
Hey there guys. I need to find the directfax 1094 document can someone help me out here and send to my email to dllantin_20@hotmail.com . Thanks
