push to start take over solution?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125176
Printed Date: April 07, 2026 at 7:41 AM
Topic: push to start take over solution?
Posted By: tianot
Subject: push to start take over solution?
Date Posted: December 20, 2010 at 9:16 PM
hi guys! im installing a compustar remote starter unit into a 2007 infiniti fx35 with a intelligent key with the turn knob and im using the ads-al bypass. my question is do i need to wire the take over solutions wiring diagram? if yes, what is the best solution diagram to use for a automatic transmission?
------------- tianot
Posted By: Mark Mizenko
Date Posted: December 20, 2010 at 10:17 PM
That module should have you wiring a relay to interrupt a wire at the IntelliKey module, which will allow you to do a takeover (able to turn the know when you get in).
Posted By: tianot
Date Posted: December 21, 2010 at 1:31 PM
hey, so i dont need to do the take over solution wiring diagram for 2007 infiniti fx35. this is suv is a intelligent key with the turn knob not a push start button.
Posted By: kreg357
Date Posted: December 21, 2010 at 4:46 PM
Make sure the ADS-AL CA is flashed with the ADS AL(DL) Ni Ver 6.21 firmware. Follow the install guide.
No need to change from the Automated Take Over, it works fine. Just give the customer a copy of the last page in the install guide ( page 67). It explains the correct way to do it without causing any error lights / messages. ------------- Soldering is fun!
Posted By: tianot
Date Posted: December 21, 2010 at 7:10 PM
thanks kreg!
so i dont need to do anything on the take over solution,i just follow the type 2 diagram and thats it.
is it eAsy to remove the lower dash cover of 2007 infiniti fx35? how about the lower cover of the steering wheel?
yhanks
Posted By: Ween
Date Posted: December 21, 2010 at 8:47 PM
two screws (10 mm head?)for the lower dash cover if memory serves me. hood release handle bracket? six phillips head screws for lower column cover.
mark
Posted By: tianot
Date Posted: December 21, 2010 at 11:09 PM
hey guys,
in what programming procedure do i need to use to prgram the ads-al bypass if i have a intillegent key with the turn knob?
is it the basic programming or the push-start programming procedure?
thanks ------------- tianot
Posted By: kreg357
Date Posted: December 22, 2010 at 5:31 AM
If it's like the the 2011 Nissan Rogue I did recently, isn't there an actual ignition key inside of the Intelli-Key FOB?
Posted By: tedmond
Date Posted: December 22, 2010 at 7:08 AM
the intellikey does use a key style knob in the ignition and if doesnt work you can remove the cover and use the metal key from the intellikey. ------------- Ted
Compustar Expert
Posted By: tianot
Date Posted: December 22, 2010 at 8:40 AM
there is a metal key inside the key fob.
what programming procedure do i need to use? the push start programming or just the basic one?
Posted By: kreg357
Date Posted: December 22, 2010 at 8:44 AM
There is no Push To Start button, just the ignition switch turn knob, right? If so, just follow the guide for programming with the key.
Posted By: tianot
Date Posted: December 22, 2010 at 4:05 PM
thank you guys!
