pkall not bypassing rx300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125184
Printed Date: April 07, 2026 at 11:46 AM
Topic: pkall not bypassing rx300
Posted By: shortcircuit161
Subject: pkall not bypassing rx300
Date Posted: December 21, 2010 at 7:39 AM
I have searched the forums and many places online and have not found what I need. I'm hoping someone can help me.
I installed a remote start (Autostart AS-2775)on a 2000 RX300 with a PKALL bypass module.
I wired everything according to the Xpresskit directions. To program it, I also followed the Xpresskit directions. I held the button down, plugged in connector 2, then connector 1, LED lit solid, released button, inserted black master remote key into ignition cylinder and did not turn. About 2 seconds later, the PKALL LED flashed 10 times as it was supposed to telling me the chip info from the black key was learned. This vehicle also needs connector 3 attached to the PKALL to allow the key to turn the car on when the bypass module isn't being used.
I thought all was good until I tried remote starting it. The starter will just keep cranking and the LED on the PKALL just flashes constantly. I have used other PK/XK bypasses before and the LED is usually lit solid when the status wire becomes active from the remote starter. I'm not sure if the PKALL acts the same way. I confirmed all my wiring was correct for both ignition wires from the remote starter and the bypass module harnesses. I even tried swapping the TX/RX wires to no avail. To confirm the problem is with the bypass module, I removed connector 1 and 2 from the PKALL and put the black key in the ignition (without turning it) and engaged the remote starter. The car started right up!! I even tried the valet (gray) key and it also started right away. I do NOT want to leave a spare key in a 556U or similar universal bypass.
Can anyone please help? I am open to any and all suggestions. Does anyone have a successful install with the same vehicle and PKALL?
I greatly appreciate any help provided. Thank you.
Posted By: kreg357
Date Posted: December 21, 2010 at 9:11 AM
Where did you connect the (-) While Running wire? Did you wire in W2W mode?
The PKALL is basically a re-badged Fortin Key-Override-All. While the wire colors might be slightly different, the connector and pin positions are the same. Take a look at the Fortin install guide for your car and their programming procedure : https://ifar.ca/download/719/preview.html ------------- Soldering is fun!
Date Posted: December 21, 2010 at 10:57 AM
I connected it to the status blue/black wire from the remote start. I also tested that wire to make sure it shows (-) right before the remote start attempts to crank the engine. I did connect it W2W and triple checked every connection with my DMM. I only tested for continuity from the harnesses to my connection at the Immobilizer harness as I can't test the actual data stream.
I will look at the diagram from Fortin and see if I missed something that wasn't on the PKALL instructions.
Thank you for the quick reply. Anything else I can check?
Date Posted: December 21, 2010 at 11:06 AM
I will say the instructions for the Fortin bypass are identical with the exception of the programming section. The instructions for the PKALL aren't as descriptive and actually missed one step (plugging in connector 3) before releasing the button to program. I will try that later today. I think I may start looking into geting Fortin bypasses if they are just rebadged as DEI.
I greatly appreciate the information.
If that doesn't work, any other ideas or suggestions?
Posted By: kreg357
Date Posted: December 21, 2010 at 4:29 PM
Going by the recent posts on the PKALL and programming problems encountered, I am glad my primary bypass module is iDatalink. If you are looking at other bypass modules, check out the offerings from iDatalink. Been using them for years with no issues. https://www.idatalink.com/helpdesk/
The PKALL does have a restriction on the number of times it can be programmed. Here is a link to check to see if it is already programmed and or locked : https://ifar.ca/en/support/products/55-key-override-all_programming_diagnostics.html
Here is another bit of info for Toyota / Lexus bypass issues : https://ifar.ca/en/support/products/47-key-override_appears_to_program_but_toyota_lexus_will_not_remote-start.html
Posted By: kgerry
Date Posted: December 22, 2010 at 4:54 PM
i don't remember ever needing connector 3 on a Toyota with a PKALL..... if it does need it you have to be sure to get it plugged in BEFORE the LED comes on and you slide the key in....
that is a fast LED... i usually sit the other harnesses in their appropriate connectors without pushing them in... then after i plug in the power connector i quickly shove in the other harness(es) before the LED comes on... then release the programming switch.....it you don't it wont program..... ------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: December 22, 2010 at 8:12 PM
The connector 3 for this Lexus is used to complete the circuit for the 2 wires that i had to cut so the factory key will still work. Doesn't make sense to me either. I will try that method you suggested kgerry. And thanks as well kreg357 for the info on the idatalink modules and the other toyota/lexus info. I had looked into those but always thought DEI products would have surpassed the others. I guess not.
I have ordered some DEI 555F "pellet" bypasses in the meantime just in case I can't get this PKALL to work. And I will never another PKALL again. I will definitely purchase some idatalink from now on and see how well they work.
Thanks again for everyone's help. I will post with an update in a day or so once I try the suggestion of plugging the other connectors quickly.
Happy Holidays!!
Posted By: kgerry
Date Posted: December 23, 2010 at 3:04 PM
555F will give you nothing but grief.... you should be able to get the PKALL working.. i use lots of them with no issues... although on these early Toyota & Lexi i use a ADS-TB from Idata... they work fine for me every time
Owner/Installer
Classic Car Audio
since 1979
Date Posted: January 14, 2011 at 1:20 PM
Thank you so much for everyone's help. I greatly appreciate it. I don't really know what I was doing wrong with the PKALL but I was able to successfully program the 555F and the remote starter works like a charm now. Another happy customer. As for the PKALL, since it will allow programming twice, I was able to use it on another vehicle without a hitch. Happy New Year to All!!!
