wiring diagram for remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125241
Printed Date: April 10, 2026 at 7:03 AM
Topic: wiring diagram for remote starter
Posted By: bmonaweck02
Subject: wiring diagram for remote starter
Date Posted: December 25, 2010 at 11:07 AM
I need to know where the following wires go to.
Lock output
Unlock output
Nuetral safety switch
Rear defogger
Tachometer Input
Brake Shutdown Wire
Parking light output
Dome light output
Door trigger input
Power for alarm system
Trunk release for aftermarket solenoid
Alarm ground
Trunk trigger
(+)Ignition 1Input/ouput
(30a Fused Igntion 2/ Flex relay Input 87
Accessory Output
(+) Starter Output (car side starter kill wire)
(+) Starter Input (key side starter Kill wire)
(+)fused(30a) Ignition Input
(+)Ignition 2/Flex Relay Output
Flex Relay input 87a key side
Fused (30A) Accessory/Starter Input
If you have a wiring diagram for how to install a viper 5701 remote starter and security system on a 2005 Chrysler Sebring Convertable (grey key) that would be greatly appreciated!
-Bmonaweck
Posted By: ayalja123
Date Posted: December 25, 2010 at 3:35 PM
go to bulldogsecurity.com, you could get all that info there under vehicle wirering.
