2010 honda accord trouble
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125258
Printed Date: May 07, 2026 at 3:17 AM
Topic: 2010 honda accord trouble
Posted By: wonderroma
Subject: 2010 honda accord trouble
Date Posted: December 26, 2010 at 2:02 PM
Hello all, I am in need of little assistance. I just finished installing a Viper 5301 remote start in D2D mode with a DB-ALL interface in my 2010 Honda Accord. Everything works perfectly except when the car is remote started the parking lights don’t come on. The lights do flash when I lock and unlock but that could just be the factory alarm doing it. I did connect the Vipers H1/11 white parking light output to the cars gray parking light wire at the switch harness. Any ideas double be much appreciated.
Posted By: kreg357
Date Posted: December 26, 2010 at 2:11 PM
Did you change the Vipers' Parking Light jumper to Negative Parking Lights?  The Accords' Gray Parking Light wire is (-) and the Viper comes defaulted at (+) Parking Light output.
Posted By: zerepdivad
Date Posted: December 26, 2010 at 2:38 PM
actually that viper comes as nothing for parking lights. under the cover on the top there will be a 10 amp fuse taped. plug it in to it's respective spot marked for - lights.
A DMM is a beautiful thing.
Date Posted: December 26, 2010 at 3:07 PM
I did put the fuse in but mabey I set it for positive. when it stops snowing I will get under the dash and take a look. I'm wondering now if I should have connected the H1/4 WHITE/ brown light flash isolation wire to the cars lights instead, the instructions say that wire goes to the alarms onboard relay.
Date Posted: December 26, 2010 at 3:14 PM
no you didn't. that wire i've only ever had to use on chryslers where i had to use a resistor as well as isolate the wire from the switch for parking lights.
Date Posted: December 26, 2010 at 3:23 PM
ok, I will double check the fuse and wire connections.
Posted By: tedmond
Date Posted: December 27, 2010 at 12:45 AM
there is prob something wrong with the park light fuse such as polarity.
it is negative, so open up the door and select the right one. And on that note, the dball controls all factory controls via data, so the light flash is comming from the honda keyless entry module, NOT from the viper, so as mentioned, the problem is from the viper.
Ted
Compustar Expert
