2005 f450 remote start problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125289
Printed Date: May 06, 2026 at 5:03 AM
Topic: 2005 f450 remote start problems
Posted By: cdcconst
Subject: 2005 f450 remote start problems
Date Posted: December 28, 2010 at 1:12 AM
Any one have any suggetions? installed a Viper 5900sst on a 2005 F450 diesel and remote start attempt to start and shuts down with in 2 seconds, then attempts to restart. Cranking time is set to 4 seconds, with a 15 sec timer. If i rotate key switch to ignition position while rs is cranking engine starts. Tach wire is connected to lt.grn w/ red at cluster.
Any ideas?
Posted By: Ween
Date Posted: December 28, 2010 at 9:47 AM
hi,
 with the vehicle key turned to ignition while remote start is attempted, vehicle starts?...check your wiring at the ignition switch, something isn't powered up.  the light GREEN/ red(s) i have at the instrument cluster are for the alternator and parking brake.  tach is light GREEN / WHITE pigtail under dash behind fusebox.
mark
Posted By: zerepdivad
Date Posted: December 28, 2010 at 11:02 PM
sounds like you may have missed an ignition wire. what all did you hook up in your ignition harness?
Also often on these trucks it's best to use a 454t tach generator.
A DMM is a beautiful thing.
Posted By: cdcconst
Date Posted: December 29, 2010 at 1:02 AM
Hello,
I was wrong i did connect the tach to a lt grn/ wht but at the cluster. This is a work truck and is pretty vanilla, i did not find any five wire harness with white tape behind the parking brake. So i attempted to follow the lt. gren / wht in the harness to the cluster. I did not check continuity though to verify ( i assumed) it was the same. The remaining wires i connected as follows.
12v red- yellow at ign harness
12v RED / wht- lt grn/ purple
ign pink- RED / lt. grn
2nd ign pink/ wht- RED / blk ( to feed aftermarket windows and doorlock controlled by alarm)
Acc orange- gray/ yellow
Tach - lt. grn/ wht at cluster
I am sure the ign wires are connected as when i go into programming mode the ign sense all works as well as when attempting to start with RS all instruments and acc are active. I am thinking i have the wrong tach sense. Would that cause this problem?
Posted By: cdcconst
Date Posted: December 29, 2010 at 1:05 AM
Also i installed the new Sony 770 double din navigation unit. It all seems to work fine with out the speed sense wire hooked up, where would i connect this wire and what function does it serve?
