2nd starter general knowledge
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125346
Printed Date: April 03, 2026 at 4:57 PM
Topic: 2nd starter general knowledge
Posted By: resquchas
Subject: 2nd starter general knowledge
Date Posted: December 30, 2010 at 12:59 PM
whats the FUNCTION or reason behind a second starter circuit/relay... I have installed only 3 remote starts so far and haven't NEEDED it so what it is used for? What can it be used for? Is it necessary on some models? I know vague but just trying to soak it all in.
------------- The RIGHT way is the ONLY way.
Posted By: kreg357
Date Posted: December 30, 2010 at 3:22 PM
Some Nissans have a second starter wire that is there for "fuel enrichment" - necessary for a cold engine start.
------------- Soldering is fun!
Date Posted: December 30, 2010 at 3:32 PM
so if the car needs it then only while it is cranking? hence the 2nd starter reference?is it just nissans. is there another use
Posted By: t&t tech
Date Posted: December 30, 2010 at 4:41 PM
No toyotas have it as well.
Posted By: kreg357
Date Posted: December 30, 2010 at 4:42 PM
Some Toyota's have two Starter wires at the ignition switch. ( Camry, Avalon, Highlander, RAV4, depends on year. )
Just the way the design engineers decided to do it.... ------------- Soldering is fun!
Date Posted: December 30, 2010 at 4:52 PM
i appreciate the knowledge guys. dont have one to do right now but i keep seeing people refer to 2nd starter.... gotta wonder why they do what they do. 2nd accesory i kinda get but starter? so its manditory if that vehicle has it, to be used. and it would generally be a necessity not lets say....another convenience function.
Posted By: t&t tech
Date Posted: December 30, 2010 at 5:15 PM
Well that question is a whole different story, we discussed it on the platforms already, look it up.
Posted By: lspker
Date Posted: December 30, 2010 at 9:34 PM
If you don't use the second start wire, the car will be difficult to start in cold, will start fine in the warm.......think of it as a choke.
Posted By: zerepdivad
Date Posted: December 30, 2010 at 9:57 PM
you should always hook up second starter. on nissans it's referred to often as the "cold start wire".
------------- A DMM is a beautiful thing.
Posted By: t&t tech
Date Posted: December 31, 2010 at 5:56 AM
This was what i thought, but then the guys on this sight informed me that this wire although being present, is not always functional, i'll see if i can locate the thread.
Date Posted: December 31, 2010 at 8:12 AM
thanks. just trying to gather info for future use. IF an alarm or RS has a second output that is cofigured for 2nd starter and is same polarity as the vehicle...then no relay right just hook up and go? I keep seeing a relay for like toyota etc. is that only if module has primary starter only.
Posted By: KPierson
Date Posted: December 31, 2010 at 8:28 AM
Many times the 2nd starter output is a low current (-) output. If so, a relay will be required.
------------- Kevin Pierson
Posted By: tedmond
Date Posted: December 31, 2010 at 10:09 AM
most units on the market have the following (+) outputs on its primary (larger gauge harness)
start ign acc parking light 5th relay (can be configurable for acc, ign, or start) and two 12v (+) inputs.
the toyota requires a relay onlybecause it is a postive start wire, whereas the unit outputs a negative. Therefor you must use a relay to convert the polarity.
if the car has a negative start, as KP mentioned, it is often 250ma up to 500ma depending on brand. You should always rather be safe than sorry, so just wire up a relay even if it is a low current system. If using a relay, remember to use a diode across the terminals to prevent backfeed on the unit which might damage the output. ------------- Ted
Compustar Expert
Posted By: KPierson
Date Posted: December 31, 2010 at 10:53 AM
All reputable manufactures include the diode assuming the low current output will drive a relay. I've never seen a unit (even cheap ones) that don't have the diode built in. The typical output section of a remote start / alarm contains a driver chip that has multiple Darlington transistor arrays with all required resistors and diodes built in.
Here is a datasheet for a very common driver chip: https://focus.ti.com/lit/ds/symlink/ulq2004a.pdf and the schematic is on page 3. ------------- Kevin Pierson
Posted By: howie ll
Date Posted: December 31, 2010 at 11:30 AM
Yes Kevin but for how long it takes to install and its cost I'd rather add one, I blew out an older G4 Clifford once by being lazy.
Also NEVER parallel out to the two starter wires, always adjust your outputs as above or relay it.
Date Posted: December 31, 2010 at 7:20 PM
time is not a concern for me. I have a unique experience, because I am firefighter/medic and work at a restoration shop on time off. kinda boutique work. the job takes whatever it takes. i get to solder evrything and heatshrink. BUT it's mostly pre computer stuff. I have been getting more late-model stuff after a couple installs made it around to some shows. so i have to try and catch up with everybody. thanks for the help evrybody
