lhs door status
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125375
Printed Date: March 19, 2026 at 10:34 PM
Topic: lhs door status
Posted By: maxcat
Subject: lhs door status
Date Posted: December 31, 2010 at 7:21 PM
Hi guys, Hopefully someone has maybe seen this issue before. Just finished a r/s install on a 2001 Chrysler LHS using a compustar 6200 and a EVO ALL bypass module from fortin. The only problem I am having is the r/s is showing the door open at all times. I am using the data-link mode and had no issues at all programming the module. I also made sure I changed option 4-11 on the compustar to make it fortin compatible. Before I go and change the wiring to non data-link, I thought I might throw it on this forum for suggestions. Like I said eveything else works fine,ie. the start,locks,trunk are working perfectly.
Thank you in advance
Posted By: tedmond
Date Posted: January 01, 2011 at 10:08 AM
goback into settings and change it again.
i never use d2d but i have heard at times you need to program that option twice.
Ted
Compustar Expert
Posted By: maxcat
Date Posted: January 01, 2011 at 11:03 AM
Thanks for the reply Tedmond, I actually wired the fortin bypass as non data-link and the door directly to the compustar, now it works fine.
  The only problem I am having now is the car running either under remote start or with the key, will not allow me to unlock the doors with the compustar remotes. It will however let me unlock with the factory remote. The compustar lock/unlock command works perfectly when the vehicle is not running.
Any help or further insight would be appreciated. It almost appears the vehicle itself is preventing the unlock,as I can hear the unlock click, trying to unlock it.
Thanks again
