viper 5901 upgraded sensor needed?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125455
Printed Date: April 29, 2026 at 8:31 AM
Topic: viper 5901 upgraded sensor needed?
Posted By: labikesrcool
Subject: viper 5901 upgraded sensor needed?
Date Posted: January 04, 2011 at 6:25 PM
So I've finished my install of a Viper 5901 unit. I've cranked the sensitivity both ways by using the remote up to 15 and tried 1 and the unit doesn't go off even when physically impacting the unit. All the doors are closed and alarm enabled. Fwiw my glass impact sensor does work. So what are your thoughts is it just a bad sensor or are there some tricks or things to check in your experience? Maybe I just need to get an external module. Thanks.
Date Posted: January 04, 2011 at 6:26 PM
I was told to include make and model so...
Viper 5901
Mazdaspeed3
2008
Sport (no stock alarm)
Posted By: tonanzith
Date Posted: January 04, 2011 at 7:11 PM
if your physically impacting the unit and it still not going off then it is either in VALET mode or a faulty unit. More likely a faulty unit if the other sensor is still activating as it also should not if in valet mode.
Gary Sather
