viper 5101 control center mounting
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125463
Printed Date: April 29, 2026 at 3:17 AM
Topic: viper 5101 control center mounting
Posted By: chrisd01
Subject: viper 5101 control center mounting
Date Posted: January 04, 2011 at 10:55 PM
About to install a Viper 5101 in a 2001 Civic. Just wondering what would be the best location to mount the Control Center. Also should it be mounted vertical or horizontal?
I saw a post where the person mounted the Control Center horizontally in the upper corner, driver side and someone responded stating it was the wrong direction. Was thinking of mounting behind the rear view mirror, in the center, horizontal.
Posted By: tedmond
Date Posted: January 05, 2011 at 8:09 AM
you mean the antenna?
antenna can go anywhere on the glass as long as its not obstructing your view. i find mounting antennas horizontal or vertical is the same (if they are small enought to do so)
for example you cant mount a compustar antenna vertically since its pretty much a foot long antenna.
Ted
Compustar Expert
Posted By: chrisd01
Date Posted: January 05, 2011 at 8:11 AM
Yes, I am talking about the following antenna.
posted_image
Posted By: howie ll
Date Posted: January 05, 2011 at 12:31 PM
I've even mounted one of the previous generation behind the front grill on a Mercedes!
The simple answer is anywhere it works and it isn't in your line of sight. Best place would be high up on the passenger side windscreen.
Posted By: t&t tech
Date Posted: January 05, 2011 at 7:17 PM
Front grill of a mercedes Howard? posted_image
