2008 sierra denali rf loop
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125542
Printed Date: April 29, 2026 at 12:36 PM
Topic: 2008 sierra denali rf loop
Posted By: gonzo114
Subject: 2008 sierra denali rf loop
Date Posted: January 08, 2011 at 9:43 AM
Hello, I'm installing a Clifford 50.7x remote start/alarm in my 2008 Sierra Denali (with factory remote start) using a Expresskit DBall and an RFLCHGM (rf loop). I plan on doing the install as D2D. The question I have is regarding placement of the RF Loop around the lock cylinder, as its my first time using an rf loop. Can it be installed just behind the factory loop or does it have to go inside the factory loop module? Thanks!
Posted By: tedmond
Date Posted: January 08, 2011 at 11:22 AM
as long as you position it in place and it works (while you can close the steering collumn) you should be fine.
Ted
Compustar Expert
