2007 chrysler sebring sedan
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125635
Printed Date: March 28, 2026 at 9:57 AM
Topic: 2007 chrysler sebring sedan
Posted By: ricardoboston
Subject: 2007 chrysler sebring sedan
Date Posted: January 12, 2011 at 6:46 PM
hi i was planning to put a avital 4103 remote starter on a 2007 chrysler sebring,as i can see ,i can not use the + starter wire , because this wire is not for remote starter so this is not like a regular car , i need to know a better way to go on this one,need to know if the xk09 its a good way to go or not,if someone can give me a start to finish direction of this instalattion ,thanks
Posted By: kreg357
Date Posted: January 13, 2011 at 11:47 AM
The XK09 will need to have the 9.Chrysler V2.07 firmware flashed on to it. If you don't have the XKLoader2 cable, make sure the seller flashes it for you.
Another option is the iDatalink ADS DLSL CA2 or ADS ALSL CH bypass modules. You would have to wire in the W2W mode but they are very reliable modules. ------------- Soldering is fun!
Date Posted: January 13, 2011 at 6:42 PM
hi i just dont get it.with wires from de relay satelite of remote starter will be connected direct to the ignition harness,and with ones i dont need to use thanks
Posted By: kreg357
Date Posted: January 13, 2011 at 7:22 PM
If you get the XK09 with the 9.Chrysler firmware follow the Type 3 install diagram on Page 5 of the guide. It shows all the wires from the bypass and the remote starter. If your car does not have a Starter wire at the ignition harness, the Violet/Brown MUX wire is used to control things.
Date Posted: January 13, 2011 at 9:26 PM
just to me make sure i get it right ,i will not use any those ign wires is that corret? thanks again
Date Posted: January 14, 2011 at 6:43 AM
hi its me again what its making me confused its the ignition wires switch ,bulldog securyti list it as this car can be wire as a any regular i mean the heavy gauge wires from the remote starter direct to the car switch ignition and DIRECTED TECH SHEET list it as this car use mux wires ? now i need some light here ,can you tell me somenthing about that thanks
Date Posted: February 05, 2011 at 7:41 PM
hi i just get the time ,for to do this remote starter ,and everthing works just fine the only thing is why the horn sound when the locks and the starter is activated? horn sound when locks and when remote starter the car ?? thanks for anyone who can give me a idea about it
Posted By: monty_77
Date Posted: February 05, 2011 at 8:14 PM
does it honk the horn when you lock with the factory FOBS then it will honk with the remote starter.
if you have it locking the doors after remote start then it will honk again if it honks with locks..
you can search the internet how to turn off the factory honk it not all that hard, might even be in the owners manual of the car.
Date Posted: February 05, 2011 at 8:30 PM
it dont honk the horn with the factory fobs only when i used the aftermarket remote for lock and starter,but is a very short sound , dont even bother but yes if i can do somenthing about it will be good thanks
Posted By: monty_77
Date Posted: February 05, 2011 at 8:33 PM
check in the setting of the remote starter if the conformation beeps are on.
Date Posted: February 05, 2011 at 8:37 PM
good move ,i will give it a try ,and i will let you know soon as i can ,but i think you just got it right thanks
Date Posted: February 05, 2011 at 8:45 PM
hi i did not hook up the horn wire so it will be impossible to have the confirmation,right? or im wrong?thanks
Posted By: monty_77
Date Posted: February 05, 2011 at 10:35 PM
if you did not hook up the horn than the conformation honks of the remote stater should not apply.
