94 grand cherokee wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125727
Printed Date: May 14, 2026 at 2:06 PM
Topic: 94 grand cherokee wiring
Posted By: rockyfarted
Subject: 94 grand cherokee wiring
Date Posted: January 17, 2011 at 11:03 PM
Anyone in here know where the red plug is for the factory alarm arm wire is (pink/orange) in the pass kick panel I can't find it, and or the power unlock wire (pink/purple) in the pass kick panel? Am I missing something here or are my wiring plugs not red?  Also how would I go about wiring up priority door unlocking so i cant press unlock once for drivers door and unlock a second time for all doors? I know my module supports it and lists it as an programmable option, what exactly has to be wired to do so?  Its a prostart 2 in 1  2 way starter with the lcd remote.  Also has anyone in here ever wired in the temp sensor to one of these modules?  Will it enable the lcd remote to show the cabin temp on it?  My wiring schematic shows the temp sensor as (optional).
Just hookup the red wire to the black.....ooops
Posted By: tedmond
Date Posted: January 18, 2011 at 12:10 AM
the plug is comming in from the door, so its real hard to get to but its there.
For the driver priority unlock, you will need to go into the driver door to tag the driver door lock actuator.
with a relay
85 - driver priority unlock from unit
86 - constant 12v
87 - constant 12v
87a - actuator wire switch side
30 - actuator motor side
prostarts are not bad, but the temperature will not be shown if you add it. Tried and tested, the prostart is NOT a true 2way system.
Ted
Compustar Expert
