viper 5901 rs with 520t
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125781
Printed Date: May 15, 2026 at 8:56 PM
Topic: viper 5901 rs with 520t
Posted By: rtenuso
Subject: viper 5901 rs with 520t
Date Posted: January 21, 2011 at 3:50 PM
Alarm: viper 5901
Acc : dei doorlocks and dei 520t backup batt
Car : Honda del sol 1994
OEM alarm : None
Problem: I was able to get everything hook up last night and was able to get to where I could do the mts sequence to active the RS(leaving the car while the engine is still running). The problem is while i try to RS the car again, it tiggers the truck tigger(520t backup batt). I have done a search and It looks like I might been a relay, if so, how would I hook this relay up?
Posted By: monty_77
Date Posted: January 24, 2011 at 12:23 AM
you remote start it and the trunk opens
is that what you are saying
Posted By: rtenuso
Date Posted: January 24, 2011 at 1:26 AM
Sorry, i guess i could be a little more clear. Viper 5901 has a instant trigger(-)/trunk trigger, it is the same wire. This is the wire that i needed to hook up to the back up battery trigger. So when i remote start the car, it triggers the instant trigger/trunk trigger, which is only connected to the back up battery. I read from another post that the car might be pulling too much power from the battery, which would trigger the back up battery module, which then triggers the alarm. I hope that makes sense.
