remote start 12 v power wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125867
Printed Date: March 24, 2026 at 1:15 AM
Topic: remote start 12 v power wire
Posted By: ricardoboston
Subject: remote start 12 v power wire
Date Posted: January 26, 2011 at 6:50 AM
some cars dont use 12v high amp so you have to go to the battery for the remote starter power, in some cases some cars use only 10amp 12 v for the power wire in this case can i remove the original fuses from the remote starter and use one 5amp just to get a little lower of the original of the car?
Posted By: Twelvoltz
Date Posted: January 26, 2011 at 7:31 AM
It really depends on the draw of the system you are installing. However, with the DEI systems I use, I do exactly what you are asking. I remove the included 30 amp fuses and replace them with what the vehicle's ignition wires are rated at. Because the DEI systems I use do not have a separate fuse for parking light input I use negative parking lights to ensure the system draw is minimal.
------------- Installer, IT support, and FFL. I need less hobbies.
Date Posted: January 26, 2011 at 11:25 AM
ok so will be not problem running a remote starter with a 5 ,10,15,20, fuse? i can see this like be more safer right thanks.
Posted By: Mike M2
Date Posted: January 26, 2011 at 3:04 PM
As long as it is enough to control the ignition of the car. I never go under the hood for power tho. If i can't get it from the switch i may use power from the BCM...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: howie ll
Date Posted: January 26, 2011 at 4:35 PM
And to add to Mike's comment, if in doubt go to the battery other wise a good candidate is usually the main constant (from battery) power supply to the fuse box.
