viper 5901 w/ xk01, 2008 hyundai veracruz
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125968
Printed Date: March 27, 2026 at 2:03 AM
Topic: viper 5901 w/ xk01, 2008 hyundai veracruz
Posted By: workin2golf
Subject: viper 5901 w/ xk01, 2008 hyundai veracruz
Date Posted: February 01, 2011 at 4:19 PM
I am installing a viper 5901 with a xpress xk01 on a 2008 hynundai veracruz. According to directed there should be no problem with the link. However, no one seems to have the clear location and color of the data wire(s). Can someone please help, I have the everything else hooked up just sitting there right now with all the fuses pulled until I can get the right wires for the xk01.
Thank you for any help.
Posted By: Twelvoltz
Date Posted: February 01, 2011 at 7:30 PM
What do you mean by 'according to directed there should be no problem with the link'?
Your Veracruz is not a limited model, correct?
The XK01 installation manual shows what wires you are looking for...both are in the driver's kick panel. Blue/Black for the 'data' wire, and BLACK/ orange for the 're-arm' wire. The Blue/Black is part of a twisted pair harness. Both of these wires can be found in the harness coming in from the driver's door.
Date Posted: February 02, 2011 at 7:56 AM
It is not a limited, and those color wires do not exist in this vehicle. That is where my problem is coming in, directed says that color wire and location is correct, however if those color wires are not even there, then I would have to think that they are wrong.
