2011 hyundai tuscon
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125999
Printed Date: April 01, 2026 at 2:21 PM
Topic: 2011 hyundai tuscon
Posted By: Msp541
Subject: 2011 hyundai tuscon
Date Posted: February 03, 2011 at 3:57 PM
Does anyone know if the 2011 Hyundai Tuscon has a immobilizer bypass? How do i know if it is US made or Canada made?
Thanks!
Posted By: t&t tech
Date Posted: February 03, 2011 at 5:03 PM
Immobiliser bypass or if the car has a factory immobiliser?, it's transponder so yes there is a bypass available i guarantee you, you have to be more specific.
Posted By: stang351w
Date Posted: February 03, 2011 at 7:03 PM
yes it will have a immobilizer. one way to know on those is there will be a green light flashing on the dash (kinds looks like a car with a key inside of it). another way to find out is to wrap the head of the key completly with tin foil and try to start the car. if it does not start then there is a immoblizer. how ever...for a 2011 you will need the additional bypass module. Idatalink makes some that are nice. there's others out there i know but i just use idatalink's. as for how to know if it's canadian or american made check the vin number. i don't know the number right off but one of the numbers / letters will be the production plant or at least where it was made.
------------- Tri County KustomZ
certified installer
Posted By: t&t tech
Date Posted: February 04, 2011 at 5:09 AM
Or check at the base of the seat belt it gives you location of manufactuurer.
Posted By: Msp541
Date Posted: February 09, 2011 at 11:24 AM
Thanks for the help, i just have regular black keys and thats why i asked if it had a chip in them, as far as idatalink i checked there website and shows nothing for a 2011 Hundai Tuscon. Also anyone know of the wiring colors for this year 2011? I am not sure if its the same as the 2010.
Thanks!!!
Date Posted: February 09, 2011 at 3:17 PM
hello, for idata link you want either the ADS-RNG-HK...if you look on there site under the products tab and drop down to connec accessories it's under that page. you will need both keys and it will need to be programed by the hyundai dealer (also keep in mind it's a one time deal...if they screw it up programming you will need another). now if you have access to a local install shop the ADS-AL-CA with the klon will work to. but you need to have the weblink cable to program it.
certified installer
Posted By: Msp541
Date Posted: February 09, 2011 at 4:18 PM
Thanks Stang351W for your help, i do have access to a shop and he deals with idatalink too so thats a good thing, i have to see if he has the ADS-AL-CA module if he does i am all set as long as he programs it right? Thanks for the help....
Date Posted: February 09, 2011 at 8:04 PM
correct....he will need to take it into the shop just due to how there programed. you need to upload the firmware, then install it to the vehicle at which time the bypass will start the klon process, then it's taken out of the vehicle and connected back to the computer for the final klon process then it's programmed to the vehicle....i know it sounds like a bit but if your guy knows what he's doing with it then it'll only take 10 min once everything is wired correctly
certified installer
Posted By: Msp541
Date Posted: February 10, 2011 at 12:56 PM
Hi Stang351w- I went to my friends shop today for the Idatalink ADS-AL-CA bypass module and it could not be programmed due to the fact that the module is not needed for a 2011 Hyundai Tucson according to the Idatalink information on the web. He connected the programming cable to the ADS-AL-CA and when he went to program it no 2011 Hyundai Tucson showed up to allow programming. He advised to me that this vehicle must not have a bypass to remote start and i should be okay. I wanted to pass along that information to you.
Date Posted: February 10, 2011 at 7:54 PM
well..don't know what to tell you on that one... I know the last couple 2010 tuscan's i've done did have the OEM immobilizer and i used that by pass for those vehicles... good luck on your install and if you do run into an issue. my best advice on that would be to call idatalink themself's and see if that would work (some i've used for 2011 vehicles are the same as 2010's)
certified installer
Posted By: Mike M2
Date Posted: February 11, 2011 at 6:38 AM
Easiest and most accurate way to know for sure is to remove the column shroud and look for a transponder ring around the ignition switch...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Msp541
Date Posted: February 12, 2011 at 9:18 AM
Thanks for the help Stang & Mike- I installed it today and no bypass transponder and went well. Thanks for the help!!
