compustar 6200, 04 silverado 3500 diesel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126025
Printed Date: April 01, 2026 at 3:01 PM
Topic: compustar 6200, 04 silverado 3500 diesel
Posted By: shortyy1
Subject: compustar 6200, 04 silverado 3500 diesel
Date Posted: February 05, 2011 at 11:16 AM
As the title says, have an 04 silverado 3500 diesel with self installed 6200, omega bypass module, I also have a banks IQ system so I can read diagnostic codes.  Had some problems with the install but this site has been pretty helpful.  I have a couple issues I could use some insight on.
When the vehicle is started with the remote start, I get a service 4WD message, with a error code lost communication with TCM.
Also I have noticed, the defroster and vents do not appear to be working, heat only blows out the at the feet.
If I start the truck with the key, everything runs fine.
Appreciate the help.
Travis
Posted By: kreg357
Date Posted: February 05, 2011 at 4:12 PM
Did you get all the ignition wires connected.  Audiovox and DirectWire list the following:
 Battery             RED  (+)          IGNITION SWITCH HARNESS
 Ignition 1          PINK  (+)          IGNITION SWITCH HARNESS
 Ignition 2          WHITE  (+)       IGNITION SWITCH HARNESS
 Accessory 1     ORANGE  (+)   IGNITION SWITCH HARNESS
 Accessory 2     BROWN  (+)     IGNITION SWITCH HARNESS
 Starter 1          YELLOW  (+)    IGNITION SWITCH HARNESS
