passlock bypassed with resistor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126086
Printed Date: March 22, 2026 at 2:09 AM
Topic: passlock bypassed with resistor
Posted By: ernmang2
Subject: passlock bypassed with resistor
Date Posted: February 09, 2011 at 6:08 PM
Hello, I bypassed the passlock on my 2000 yukon due to intermitend no starts with the resistor method and it starts up every time no problem but the security light is staying on
any ideas??????
Posted By: brcidd
Date Posted: February 09, 2011 at 7:31 PM
Probably because it "sees" the resistance in every key position, including "off" now....  Did you activate the resistor during "on" and "start" and have it not be on while in "off"?
Brcidd - Engineer That Does Remote Starter Installs on the side.
Posted By: ernmang2
Date Posted: February 09, 2011 at 7:37 PM
I cut the yellow wire while it was runnig... and soldered the resitor in between the stripped back orange and black wire, to the truck side yellow wire all done while truck was running.
Posted By: ernmang2
Date Posted: February 09, 2011 at 8:12 PM
I thick I should have cut the yellow wire with the vehicle NOT running, thats the resistor method.
If you cut it while running it puts the system into a full blow dissable mode and security light stays on.
now does anyone know if I get the codes cleared will it then start looking at the resistor. or is this computer unable to reset??
can I just disconnect the batt.
Posted By: zerepdivad
Date Posted: February 09, 2011 at 9:48 PM
what resistance value did you use? did you even meter it? and use that resistance?
pretty sure at this point if you unhook the battery it wont start.
A DMM is a beautiful thing.
Posted By: ernmang2
Date Posted: February 10, 2011 at 4:46 AM
2.2k resister... I had the
Batt. Off for a couple minutes and it started right up (prob not long enough)
I don't think it's looking at the resister at all at this point, from what I have been reading I am in full bypass after cutting the yellow while running. Light will stay on.
I think I need to clear faults and let the vehicle learn the new resistance value....
Posted By: blanx218
Date Posted: February 10, 2011 at 10:02 AM
the vehicle doesnt learn resistance. you have to measure the resistance that it needs, use that resistor and wire it up with a relay that is only on during crank
Posted By: ernmang2
Date Posted: February 10, 2011 at 10:10 AM
Thx, I thought it learned? I did an s10 and just wired in the resister...
Would you have a schematic of the resister/relay setup you could send me?
Thanks,
Can I put in a 555 module or something.. for this without doing a full remote start?
Posted By: jseibold
Date Posted: February 10, 2011 at 11:54 AM
I have used the method you are describing too many times to count.  Here is how I have always done it:
With the vehicle running, cut the yellow wire (the security light will come on).  put the red lead of your meter on the cut yellow wire (key side) and your black meter lead on the ORANGE / black.  Record the resistance.  Then flip flop your meter leads putting the black lead on the cut yellow wire and the red lead on the ORANGE / black.  Record the resistance.  The 2 resistance values may be different.  Go with the higher value and make sure you use a resistor or combination of resistors that is right on the higher value.
Then do just as you have:
hard wire the resistor permanently accross the ORANGE / black and vehicle side of the yellow wire.  You should not need a relay and it will not matter if the resistor is hardwired even without the key on.
I'm thinking that your current resistor is not the correct value and that is why your security light is on.  As far as the reference to only having resistor on during crank, that applies to Passlock 1 (along with bulb test wire) and your truck has Passlock 2
Posted By: ernmang2
Date Posted: February 10, 2011 at 12:36 PM
Thats how I have done other vehicles, if I were off by that much on the resister I would think it would not start.
Posted By: brcidd
Date Posted: February 10, 2011 at 12:59 PM
You should wire a relay such that the resistor is active only during ignition on-- just like the ignition swith does it.  In the diagram below, you could ignore the remote start activation latching relay on the left and simply permanently ground the 86 terminal on the relay on right.  Follow instructions to measure the resistance and pick out the exact resistor for your bypass.
posted_image
Posted By: ernmang2
Date Posted: February 12, 2011 at 12:15 PM
Followed the above and,
my resistance measurement is 2.6 and when I switch the leads I get erratic info. 1.x all the way up to 3.0 then "ol" I put in a 2.7 it started fine then  i set off the alarm to check ... now it won't start, shouldn't it still bypass the security, it should think the key is in and start?? What am I missing ??? it act as if it still only is looking at the key
