nissan maxima 2004 viper 5301
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126116
Printed Date: March 22, 2026 at 5:56 PM
Topic: nissan maxima 2004 viper 5301
Posted By: manorios
Subject: nissan maxima 2004 viper 5301
Date Posted: February 11, 2011 at 8:59 AM
I have a 2004 Nissan Maxima. I purchased the Viper 5301 remote start. I am also using the DB-ALL (by Xpresskit) immobilizer bypass. I have reprogrammed the bypass with the Nissan firmware.
I have all my wires from my car ready to be spliced into. I have the wires that i need noted and tagged. I know that the unlock and lock work from the viper remote. I have D2D connected between the viper and the bypass. i programmed the bypass with my key already.
I need to know what wires i need to connect between the viper and the car(minimal) to have the car start. I do have all the harness' coding for the viper so please be specific .
Thank you in advance
Posted By: howie ll
Date Posted: February 11, 2011 at 12:59 PM
Look on the vehicle wiring section, it's all there.
Posted By: t&t tech
Date Posted: February 12, 2011 at 4:09 PM
Minimal for the car to start are
power and ground (red and black) on the h1 harness
BLACK/ white neutral safety to ground
all reds on the heavy gauge harness to a proper 12volt source, pink to ignition, pink/white to second starter programmed accordingly and purple to the primary starter wire.
Plug in toggle switch
antenna plugged in.
program to voltage and off you start.
Posted By: manorios
Date Posted: February 12, 2011 at 5:50 PM
Thank you t&t tech for your response; here's another
I have hooked up my starter yesterday before you posted. I have a minor change. I hooked up the pink/white wire to ACCESSORY /HEATER BLOWER 1 and ACCESSORY /HEATER BLOWER 2. The car does start this way as well.
Should I rewire that wire to 2nd starter as you stated? what could happen if i do not? Also I have wired the purple wire to both starter 1 and starter 2.
Thank
Posted By: howie ll
Date Posted: February 12, 2011 at 6:03 PM
Dangerous, wire purple to starter 1, branch off purple wires as follows through a relay.
Purple branch to 86
Ground to 85
Constant 12v+ via 30amp fuse to 87, 30 to second starter wire.
Posted By: t&t tech
Date Posted: February 12, 2011 at 7:18 PM
Connect the pink white to the second starter and program it accordingly and connect the orange accessory wire to the second ignition so the a/c will be powered during remote start. You won't need to complicate things with a relay this way, What happens when you try to remote start?
