2010 ford edge factory alarm /disarm wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126167
Printed Date: April 18, 2026 at 6:35 AM
Topic: 2010 ford edge factory alarm /disarm wire
Posted By: gregbbb
Subject: 2010 ford edge factory alarm /disarm wire
Date Posted: February 15, 2011 at 5:23 PM
Hi
I am installing a 5901 viper in a 2010 Ford Edge
I cant find the factory alarm /disarm wire there is no such color to match the diagram.
I have some suspects how do I check for this with my DMM
Posted By: Twelvoltz
Date Posted: February 15, 2011 at 7:53 PM
It's the PURPLE / brown in driver's kick or at the BCM. To test if it's the right wire, put a key in the driver's door cylinder and turn it to unlock. Each time you turn the key to the unlock position the wire will show ground.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: gregbbb
Date Posted: February 15, 2011 at 8:05 PM
Yeah I dont see a PURPLE / brown, I see a purple and orange will the wire sit at ground and when you unlock it it unground for a split second?
Can you use a factory key fob to lock and test rather then the door lock?
Posted By: gregbbb
Date Posted: February 15, 2011 at 9:50 PM
Is that SJB Smart Junction box mounted to the driver side kick if so thats a bugger to get to!!
Posted By: Ween
Date Posted: February 15, 2011 at 10:03 PM
did you check to make sure the vehicle has a factory alarm? roll window down. lock door with remote or with lock switch, then shut door. wait a minute. reach in to open door from inside handle, see if alarm sounds. my info doesn't show an alarm available on the '10 Edge.
if it has an alarm, check the upper left hand connector of the SJB/ fuse box under the dash for the elusive violet/brown wire.
mark
Posted By: zerepdivad
Date Posted: February 16, 2011 at 12:41 AM
It's going to be way up at the top of the junction box. It's very hard to get to unless you're alittle scrawny guy but it's there. provided the vehicle actually has a factory alarm.
------------- A DMM is a beautiful thing.
Posted By: gregbbb
Date Posted: February 16, 2011 at 1:24 AM
Its late so I dont want to wake the family but I think your right there is no wire that color my hand are cut up to prove it I will let you know
later when all are awake
Guys
Posted By: gregbbb
Date Posted: February 16, 2011 at 12:38 PM
Nope you were right no alarm!!!
What kind of 2010 car don't have an alarm???????
Thanks!!
