compustar remote weird
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126200
Printed Date: April 18, 2026 at 12:56 PM
Topic: compustar remote weird
Posted By: j-tran
Subject: compustar remote weird
Date Posted: February 18, 2011 at 8:38 AM
Hi sometimes when I remote start the car I hear two beeps then the screen shows the word IDLE an then when try to press a button is says US-4 so I don't know what's wrong with it. Hope u guys can help me with this
Posted By: dvsrydin
Date Posted: March 05, 2011 at 3:21 PM
I'm having the same problem too - happens more often than not now that I get the US-4.
Have you recently had a dead battery? I'm wondering if that is the cause, as I think this started happening after I had to charge my battery after it died. (can't rememeber)
Posted By: enice
Date Posted: March 06, 2011 at 1:07 PM
The battery is running low. Change the battery. Use Duracell or Energiner
Posted By: dvsrydin
Date Posted: March 06, 2011 at 1:40 PM
Guess I should clarify - my car battery died. I'm wondering if that's what caused the command start to mis-function.
I'll try replacing the battery in the command start remote though - thanks.
Posted By: Velocity Motors
Date Posted: March 09, 2011 at 7:06 PM
There has been issues with the 9000SS remote controls. It's been identified by Compustar as a battery drain problem on these remote controls. If your remote battery only lasts 1 month, return the remote to the place you had it installed and get a replacement one.
------------- Jeff
