Door Triggers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12625
Printed Date: March 28, 2026 at 10:06 PM
Topic: Door Triggers
Posted By: DjIQ
Subject: Door Triggers
Date Posted: April 23, 2003 at 1:17 PM
How do you know if you have a (+) or (-) door trigger, I want to install neons to come on when i open the doors and go off when i close them, and im having some problems wiring them, when i ground them and hook the positive of the neons to the door trigger they do the opposite of the dome light, the come on when the doors are closed and off when the doors open, pls help!!!!
Posted By: ALARMTEK
Date Posted: April 23, 2003 at 2:52 PM
What car is it and I will show you the wires.posted_image
Robert Martin/Owner
ALARMTEK ONLINE
www.ALARMTEKONLINE.com
Posted By: DjIQ
Date Posted: April 24, 2003 at 9:11 AM
Its a 1986 Honda Prelude 2.0si
Posted By: ALARMTEK
Date Posted: April 24, 2003 at 9:16 AM
This car has a negative (-) door trigger system, as
well as (-) negative door locks.
Honda Prelude 1986
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: WHITE/ BLACK AND WHITE IGNITION SWITCH HARNESS
Starter Kill: BLACK/ WHITE IGNITION SWITCH HARNESS
Ignition +12 Volts: BLACK / YELLOW IGNITION SWITCH HARNESS
Parking Lights: RED / BLACK (+) AT LIGHT SWITCH OR FUSE BOX
Dome Lights/Supervision (ALSO CALLED DOOR TRIGGER):
BLACK/ WHITE (-) WHITE CONNECTOR RIGHT OF
STEERING COLUMN
OEM Horn: BLUE/RED (-) STEERING COLUMN HARNESS
Power Lock: GREEN / WHITE DRIVER'S KICK PANEL *
Power Unlock: GREEN/ RED DRIVER'S KICK PANEL *Trunk Release:
Alarm Input Wire: BLACK/ WHITE (-) WHITE CONNECTOR RIGHT OF COLUMN
* See Note -
Negative Pulse Door Lock Diagram
at www.RELAYHELP.com
Remote Starter Wiring Colors and Notes
Start: BLACK/ WHITE IGNITION SWITCH HARNESS
Ignition #1: BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #2: IGNITION SWITCH HARNESS BLUE/WHITE
Ignition #3: IGNITION SWITCH HARNESS WHITE/ RED
Accessory: White IGNITION SWITCH HARNESS NOT GROUNDING TYPE
Brake Light: (+) AT SWITCH ABOVE BRAKE PEDAL GREEN/ BLACK
Tach Signal: Green AT COIL
Headlights: Head Lamp : BLU/RED (-) AT SWITCH
(NOT RECOMMENDED POP-UP MOTORS ARE SEPARATE CIRCUIT)
Horn (Relay) : BLU/RED (-) AT STEERING COLUMN
Wiper : BLU/YEL (-) LEFT OF STEERING COLUMN
Radio Specifications
Type : DIN
Depth : 7 1/4"
Kit : YES
Antenna Information
Type : STANDARD
Radio Notes *
Memory : BLU/WHT
Ignition Pwr : YEL/RED
Ground : BLK
Illumination : RED / BLK
Front Speakers *
Kit : FACTORY GRILL
RF(+) : RED / GRN
RF(-) : BRN/BLK
LF(+) : BLU/GRN
LF(-) : GRY/BLK
Rear Speakers *
Kit : FACTORY GRILL
RR(+) : RED / YEL
RR(-) : BRN/WHT
LR(+) : BLU/YEL
LR(-) : GRY/WHT
DONE.
Should be a snap now!
ALARMTEK
Robert Martin/Owner
ALARMTEK ONLINE
Posted By: DjIQ
Date Posted: April 24, 2003 at 9:43 AM
Thanks a Bunch!!!
