2007 ford f150 door lock problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126275
Printed Date: April 18, 2026 at 8:56 AM
Topic: 2007 ford f150 door lock problems
Posted By: pchookhae
Subject: 2007 ford f150 door lock problems
Date Posted: February 23, 2011 at 2:55 PM
I installed a Viper alarm in this F150 but now the door lock switches don't work. I used two relays and followed the 5 wi configuration. The door locks and unlocks with the alarm but not with the switches now. I used the Pink / YELLOW and the Pink/Green wire. Please help!!!
Posted By: kreg357
Date Posted: February 23, 2011 at 3:10 PM
The 2007 F150 door locks are standard Type B (-).   No need for relays or 5 wire set-up with most remote starters that output a straight (-) pulse for Lock and Unlock.   The wires can be found in the lower half of a large bundle of wires leaving the Driver Kick Panel and heading under the drivers door sill going towards the rear of the truck and your colors are correct.
