valet key
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126334
Printed Date: April 18, 2026 at 3:34 AM
Topic: valet key
Posted By: t&t tech
Subject: valet key
Date Posted: February 27, 2011 at 11:11 AM
What's the reason for a valet key? I've always seen it on the fourums but never knew what it's purpose was.
Posted By: brcidd
Date Posted: February 27, 2011 at 2:27 PM
Typically on a 2 key system- it turns on ignition and opens door, but does not open glove box or trunk- so that a high class joint's parking valet has access to your car but not to your valuables...but times have changed- we now have one key does it all systems - so some may say a valet key will be one that opens door, but does not have a transponder in it to start car- I typically call that a service key....just my thoughts on the matter..
------------- Brcidd - Engineer That Does Remote Starter Installs on the side.
Posted By: t&t tech
Date Posted: February 27, 2011 at 4:09 PM
Thanks man i appreciate your contribution. Anyone else?
Posted By: howie ll
Date Posted: February 27, 2011 at 4:54 PM
Also use it when installing a 556 type unit in BMWs,the regular key "talks" to the car and it won't lock etc. when using an R/S.
Posted By: Mike M2
Date Posted: February 27, 2011 at 6:40 PM
Pretty much as described, on Toyota's the Valet doesn't do trunk or glove box. That is all changing as new Toyota's are not including them...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: tedmond
Date Posted: February 27, 2011 at 9:37 PM
brcidd said it all.
also, you bypass modules wont program with valet keys, not sure why. different immobilizer code?
------------- Ted
Compustar Expert
Posted By: eliashdod
Date Posted: March 01, 2011 at 9:22 PM
I have remote start from Autostart. Recently appeared "V" on the screen and doesn't allows to me to start my car. I guess, it's the valet key. How to disable it? I Can't find user's manual.
Posted By: howie ll
Date Posted: March 02, 2011 at 12:09 AM
Nothing to do with Valet key, my guess is you've placed the alarm in valet mode, check your owner's manual.
Posted By: t&t tech
Date Posted: March 03, 2011 at 5:24 AM
LOL.
