viper 5901, 2003 chevy impala
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126349
Printed Date: May 13, 2026 at 6:16 AM
Topic: viper 5901, 2003 chevy impala
Posted By: jalvarado01
Subject: viper 5901, 2003 chevy impala
Date Posted: February 28, 2011 at 3:39 AM
ok i just got the viper 5901 and i want to install it to my chevy impala 2003 i need some help with the wiring for the chevy impala
JUAN ALVARADO
Posted By: Twelvoltz
Date Posted: February 28, 2011 at 6:28 AM
Top of page, 'vehicle wiring' link will take you to a search page. That search will show you 03 Impala.
Date Posted: February 28, 2011 at 10:21 AM
WILL I NEED ANY RELAYS
JUAN ALVARADO
Date Posted: February 28, 2011 at 6:32 PM
1. All caps is considered yelling. Trying to get help from people and yelling at them is not going to get you much help.
2. You need to tell us what you plan on hooking up and what you don't to know if you need relays. To just hook up the Alarm/RS portion of the system then you need one relay to power the second accessory.
Date Posted: February 28, 2011 at 7:05 PM
sorry about that I didn't know
as soon every thing is deliver I well write back and let you know thank you for your help
JUAN ALVARADO
Date Posted: March 16, 2011 at 12:43 AM
ok check this out  im installing a viper5901 in to my vehicle which is a chevy impala 03 the installer is telling me that i have the wrong bypass module i have xpresskit xk09 solex series  he trying to sale me  xpresskit xk 01or 07  if any one can tell me whats so diffrents and should i just look for a diffrent installerposted_image
JUAN ALVARADO
Posted By: kreg357
Date Posted: March 16, 2011 at 4:29 AM
The XK09 with 9.DLPKGM v2.03 firmware is listed for you 2003 Impala.
https://www.xpresskit.com/VehicleCompatibility.aspx?p=-1&year=2003&make=Chevrolet&model=Impala&ps=1&s=0
However, the install guide has this interesting note for the required Type 3 install :
In some vehicles, the DLPKGM may only bypass the Passlock II via data Once programmed, test the
door lock inputs to determine if the DLPKGM will activate these functions via DATA. If there is
no activation, then the door lock system will need to be controlled analog via the remote starter.
I have never used an XK09 in a 2003 Impala, so I can't say if it will work and do everything it
is listed as doing or if that note will apply.  If your installer is a authorized DEI dealer, he
should know what works best. ( They do list the XK09 and the XK01 but not the XK07.)  The XK09
and the XK01 both have the same retail price, while the XK07 is $10 more.
