2007 jeep grand cherokee, 5901, dball, probs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126354
Printed Date: May 13, 2026 at 4:26 AM
Topic: 2007 jeep grand cherokee, 5901, dball, probs
Posted By: lewi3069
Subject: 2007 jeep grand cherokee, 5901, dball, probs
Date Posted: February 28, 2011 at 11:21 AM
Alright I need some help. I am trying to set up a Jeep with a 5901. Currently I followed all directions to the "T". I have a problem when I look up everything to the 5901 the siren just wants to keep going off as long as its plugged in. I cannot really go anything because of this issue... The Siren sounds messed up like there will be changes in volume if I hit the lock on the remote. If I need to write out what wires are where or if more detail is needed let me know.
Thanks all in advance.
Posted By: Twelvoltz
Date Posted: February 28, 2011 at 11:47 AM
Sounds like you may have the siren wired up incorrectly. What is the LED doing when the siren is going off?
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: lewi3069
Date Posted: February 28, 2011 at 11:50 AM
Hmm... The led wasnt doing anything. I have the red (from siren) to brown on main (12pin if i remember correctly) black on siren to neg battery
Date Posted: February 28, 2011 at 6:09 PM
That tells me you probably have a bad system ground.
Posted By: lewi3069
Date Posted: February 28, 2011 at 11:17 PM
It was a ground issue Thanks. Now the remote start isn't working... Any ideas? I did reprogram the DBALL, but still no remote starting. Fixed the door locks not working. I will dig into the starter this weekend more.
