viper 5701
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126637
Printed Date: April 25, 2026 at 3:47 PM
Topic: viper 5701
Posted By: bigjake21782
Subject: viper 5701
Date Posted: March 20, 2011 at 1:47 PM
One quick question. How can I prevent my cars parking lights from flashing with this unit installed. I'm sure there is some way. I just don't want the visual confirmation.
Jake
Posted By: howie ll
Date Posted: March 20, 2011 at 3:50 PM
Refer to your programming sheet.
Posted By: dasbogie
Date Posted: March 20, 2011 at 3:53 PM
Do not connect the white parking light wire. Also, you didn't post year make and model so it is hard to say if it will flash with lock and unlock. If you are using a data bypass it may flash the lights regardless of the viper
------------- Advanced
Date Posted: March 20, 2011 at 4:04 PM
Pretty sure I've done that already but thanks anyway
Date Posted: March 20, 2011 at 4:06 PM
2011 Honda crv. It uses the pkall as the bypass. so basically if I go cut the white parking light wire everything will work like normal but my parking lights won't turn on. You don't think that will stop the unlock and lock flash though
Jake
Posted By: buddholly
Date Posted: March 20, 2011 at 6:02 PM
Either cut it and isolate it or just pull the fuse out.
Date Posted: March 20, 2011 at 6:03 PM
Oh yeah, it will cause your lights to not flash on lock/unlock as well. If they are flashing after remote start you can change the settings on the Viper to constant parking lights instead.
Date Posted: March 20, 2011 at 6:04 PM
Which fuze. The cars parking light fuze or is there on in the module. Also will this stop them from flashing on unlock and lock. That's my main thing I'm trying to figure out
Jake
Date Posted: March 20, 2011 at 6:10 PM
Stupid iPad and autocorrect picked up fuze instead of fuze. Next question is what about the white wire with brown tracer. Light flash. What does that one exactly do
Thanks again
Jake
Date Posted: March 20, 2011 at 6:12 PM
Yes it will also stop the lights from flashing during lock and unlock. There is a little panel on the viper unit that unsnaps, thats where the fuse is located. If you still want confirmation for your door locks you could hook up the horn trigger...it will honk once for lock and twice for unlock.
Date Posted: March 20, 2011 at 6:13 PM
BROWN / White I typically use on Chryslers to isolate the parking lights...don't need it on this car.
K I'm going to try pulling the fuse and see if that works now. Thanks for the tip
Date Posted: March 20, 2011 at 6:16 PM
Well if it's a 5701 the siren will chirp, so never mind the horn trigger comment.
Date Posted: March 20, 2011 at 6:42 PM
Bingo! Thanks so much. No more parking light flash. They still work as normal with the switch though as they should. Siren chirps and everything is good. Thanks for the help buddholly
Jake
