honda accord 2001 hatchback alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126679
Printed Date: April 18, 2026 at 8:56 AM
Topic: honda accord 2001 hatchback alarm wiring
Posted By: afterburner27
Subject: honda accord 2001 hatchback alarm wiring
Date Posted: March 23, 2011 at 2:16 PM
Some help me with code tabel accord 2001 1.8vtec , keyless entry fitted genuine honda without alarm.
Want to fit a concept 650 G5.
Pse help with colorcode wiring.
l + r turnsignal
brakelight, central doorlocking system, ign wires .........
Regards Nico
Posted By: syl20rochon
Date Posted: May 14, 2011 at 7:59 PM
There you go...hope it helps...
FUNCTION     DATACOLOR     LOCATION     POLARITY     PICTURE
+12 Volts     White     Ignition Harness     +
Ignition     BLACK / YELLOW     Ignition Harness     +
Ignition 2     N/A     N/A     N/A
Accessory     Yellow     Ignition Harness     +
Accessory 2     N/A     N/A     N/A
Starter     BLACK/ white     Ignition Harness     +
Starter 2     N/A     N/A     N/A
Tachometer     Blue     At coil module     AC
Injector     N/A     N/A     N/A
Parking Lights     RED / Black     In green connector behind fuse box     +
Brakeswitch     WHITE/ Black     Brake Switch     +
Clutch Bypass     N/A     In green connector behind fuse box     +
Parking Brake     GREEN/ Red     At switch     -
Hoodpin     N/A     N/A     N/A
Glow Plug     N/A     N/A     N/A
Lock     BLACK/ Blue     Passenger's Kick Panel     -
Unlock     Orange     Passenger's Kick Panel     -
Trunk Release     WHITE/ Red     Fuse box, gray connector ***     +
Arm     With Lock     Passenger's Kick Panel     -
Disarm     With Unlock     Passenger's Kick Panel     -
Doorpin     BLACK/ white **     Connector in fuse box     -
Trunk Pin     N/A     N/A     N/A
Security: OEM ALARM,TRANSPONDER
Comments: * VEHICLE IS EQUIPPED WITH A TRANSPONDER ANTI-THEFT SYSTEM.
** DOORPINS:DOMELIGHT DELAY WILL CAUSE PROBLEMS WITH READY MODE IN MANUAL TRANSMISSION CAR STARTERS WHEN USING THE BLACK/ WHITE WIRE. USE THE DOORPIN WIRES AND NOT THE DOMELIGHT FOR MANUAL TRANSMISSION STARTERS ( MUST BE DIODE ISOLATED). DRIVER SIDE: GREEN/ ORANGE (-) REAR DRIVER SIDE: GREEN/ YELLOW (-). BOTH FOUND IN DRIVER SIDE FUSE BOX. PASSENGER SIDE: GREEN/ WHITE (-) REAR PASSENGER SIDE: GREEN (-). BOTH FOUND IN PASSENGER SIDE FUSE BOX.
*** FRONT LEFT OF DRIVER'S SIDE FUSE BOX.
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
Posted By: howie ll
Date Posted: May 15, 2011 at 1:54 AM
Turn signals GREEN/ YELLOW and GREEN/ blue at the ignition loom or floor loom.
Locks on Euro versions are 5 wire, loom from dash to drier's door.
Brakes, GREEN / WHITE I think, look at brake switch.
BLACK/ white starter.
BLACK / YELLOW ignition.
Sorry Sylvain, the lock wiring is different on Euro versions.
Can't remember trunk trigger but again it and the door trigger can be picked up at rear of instrument panel.
Posted By: howie ll
Date Posted: May 15, 2011 at 2:09 AM
DEI gives blue/white or pink/black lock and GREEN/ red or GREEN/ orange unlock, neg. pulse, (type "B"), green plug, base of fusebox.
Trunk trigger orange.
That's from DEI international sheet for that vehicle and year, except I never found those wires.
Unfortunately all of my installs were on right hand drive vehicles so I can't be of any more help.
The DEI instructions were extremely sparse I only had to go to the dome light trigger. Once the car is locked, it extinguishes the dome light and a 650 has a built in 4 second delay so no problems or supervision required.
The Honda (and generally Japanese manufacturers) is local build and the models differ market to market. Just Google Honda UK and look at the Civic, especially the interior.
Date Posted: May 15, 2011 at 4:24 PM
I didn't know that accords were different down there, sorry for my ignorance.
Sylvain Rochon
I'm here to help.
Posted By: howie ll
Date Posted: May 15, 2011 at 5:23 PM
Don't worry you weren't to know
