viper 5901 remote start, 98 altezza
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126710
Printed Date: April 18, 2026 at 6:47 AM
Topic: viper 5901 remote start, 98 altezza
Posted By: monks
Subject: viper 5901 remote start, 98 altezza
Date Posted: March 24, 2011 at 10:38 PM
i have a a viper 5901 wired on my 98 6 speed altezza but the remote start its not activating each time i get remote start error on the remote 7 flashes i went throught the steps as stated in the book but the same problem
can i have some insight into this
Posted By: blanx218
Date Posted: March 24, 2011 at 11:11 PM
Is this system new or has it been in for a while and no longer working? what steps are you taking?
Posted By: monks
Date Posted: March 24, 2011 at 11:52 PM
it is a new system just installed on the car as it stand now dont know how to move forward
Posted By: blanx218
Date Posted: March 25, 2011 at 12:02 AM
if you're doing the remote start initialization correctly it should stay running until you lock the doors. does it do that?
Posted By: monks
Date Posted: March 25, 2011 at 12:11 AM
no it doesn't reach that far
everything else on the system works and works well
when i go through the steps to initialize the system it show remote start error on the remote and u get 7 flashes
Posted By: blanx218
Date Posted: March 25, 2011 at 12:25 AM
So you're getting the remote start error when you attempt to activate the remote start with the car running, after you put the e-brake on? For programming, how many pulses to activate do you have it programmed to. The default is 1. If you program it to 2 or 3. the remotes are very picky how fast/slow you press the button.
Posted By: monks
Date Posted: March 25, 2011 at 12:29 AM
yes its at default so its at one
cant seem to figure out this thing
Posted By: blanx218
Date Posted: March 25, 2011 at 12:33 AM
do you have the neutral safety switch plugged in and turned on?
Posted By: buddholly
Date Posted: March 26, 2011 at 2:54 PM
Are all of the doors and hood shut when you are putting it in manual transmission mode?
