clifford 590.2x
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126765
Printed Date: March 22, 2026 at 7:24 AM
Topic: clifford 590.2x
Posted By: wtr1986
Subject: clifford 590.2x
Date Posted: March 29, 2011 at 1:21 AM
Im putting in a clifford 590.2x with window module and a DBALL xpresskit, I need wiring diagrams and locations please.
Posted By: wtr1986
Date Posted: March 29, 2011 at 1:23 AM
Sorry its for a 2005 Honda Accord EX V6
Posted By: howie ll
Date Posted: March 29, 2011 at 3:04 AM
Look on the vehicle wiring section please.
Posted By: wtr1986
Date Posted: March 29, 2011 at 11:40 AM
Ok i need help finding where to connect these wires to
H2 harness 18pin
-H2/10 status output
-H2/11 flex relay control output
-H2/16 status output two
H3 harness 10pin
-H3/1 ignition 1 input/output
-H3/6- fused 30A ignition 1 input
H3/9 fused 30A accessory/ starter input
For H2/12, H2/13,H2/14 (accessory, starter and ignition output) can they be tied into the remote start harness wires Remote H3/1, H3/3, H3/4
Posted By: smokeman1
Date Posted: March 29, 2011 at 4:42 PM
You will need to find, test and verify ALL wires on your car before connecting wires from the remote start unit.
If you don't have a DMM for testing, you are Guessing.  Download the Viper 5701 install manual from this site. On page 13 is a section on how to find the wires you need.
Do a search on this site for other info on a 2005 Accord that might help you.
Car        R/S Unit
12 volts constant  (White)+                                                     H3/2, 6, & 9
Starter (BLACK/ White) +                                                            H3/5
Ignition 1 (BLACK / YELLOW) +                                                      H3/1
Accesory 1 (BLACK/ Red) +                                                        H3/3
Accesory 2 (WHITE/ Red) +                                                        H3/7  Will have to be set as Accessory
H2/10   connects to your bybass module
Wiring Chart from the Bulldog Guys:  https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Posted By: blanx218
Date Posted: March 29, 2011 at 7:52 PM
The H2/12, 13, 14 wont be used on this vehicle
