2008 toyota sienna door trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126875
Printed Date: March 19, 2026 at 3:31 PM
Topic: 2008 toyota sienna door trigger
Posted By: drclark
Subject: 2008 toyota sienna door trigger
Date Posted: April 07, 2011 at 1:05 PM
I have found the door trigger for the Driver side and the hatch, but I cannot find the passenger door triger (RED / Yellow). Where exactly is it?
I also need help finding the sliding door triggers.
The information posted by AudioVox is incorrectly. They said to use blue (-) at the dash and it is not correct.
Please help and thank you..
Posted By: ecarsecurity
Date Posted: April 07, 2011 at 2:15 PM
SLIDING POWER DOOR YELLOW /GREEN (-)
Below DASH JUNCTION BLOCK, (WHITE, 22-Pin Plug) Pin 11
------------- -ECarSecurity
Car Security, Remote Starters & more.
Posted By: Mike M2
Date Posted: April 07, 2011 at 3:42 PM
The blue wire is certainly correct. It is located at the the dome light switch left of the column and covers all 5 doors.
| Power Sliding Door (Left) |
YELLOW /GREEN |
bottom left of fuse box, 22 pin plug, pin 11 |
| Power Sliding Door (Right) |
purple |
bottom left of fuse box, 22 pin plug, pin 9 | ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: drclark
Date Posted: April 07, 2011 at 4:20 PM
Thank you so much.
Would you guys confirm if passenger door trigger is RED / yellow? Just wondering if I am looking for the wrong wire.
Thank you and thank you again.
Posted By: drclark
Date Posted: April 07, 2011 at 4:45 PM
YELLOW /GREEN |
purple |
Hi Mike,
Sorry for sounding like a retard, but I tested the blue wire located on the interior light switch and it does not show any power when the door is opened or closed. The interior light switch is located on the left side of the stereo player and below the window defroster. Is this the switch you are referring to? It has the word "Off|Door|On" on it. Please help and thank you again.
Posted By: Mike M2
Date Posted: April 07, 2011 at 7:35 PM
Sorry for that, thinking Tundra for a second. The switch is located next to the heater controls in that oblong panel. The blue will show ground when a door is open. I've done literally hundreds of them and have always used this wire...
Tech Manager
CS Dealer Services
Posted By: howie ll
Date Posted: April 08, 2011 at 4:51 AM
Current Toyotas require no dome supervision, the dome switched ground as Mike mentioned is good for all of the doors, it will shut down immediately the vehicle is locked.
Posted By: drclark
Date Posted: April 08, 2011 at 11:58 AM
Yes, the blue wire works.
Thank you for all your help.
