07 yaris trunk release
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127526
Printed Date: April 05, 2026 at 5:09 PM
Topic: 07 yaris trunk release
Posted By: mbsaudio
Subject: 07 yaris trunk release
Date Posted: June 02, 2011 at 6:07 PM
anyone have info on trunk release wire on a 2007 Yaris. It must have one 'cause it is on the factory keyfob but there is nothing listed on the site.
Posted By: smokeman1
Date Posted: June 02, 2011 at 9:03 PM
Try this link:
https://techservices.audiovox.com/TechnicalIndex.aspx
Posted By: blanx218
Date Posted: June 03, 2011 at 12:11 AM
DEI doesnt list anything, but when all else fails, access the wiring harness going to the motor, use a dmm and figure out the motor wire, and hook up a 5wire relay.
Posted By: howie ll
Date Posted: June 03, 2011 at 4:57 AM
Audiovox lists white + at the front fusebox so find your wire then if the alarm's trunk release is a low current e.g. under 300milliamps neg pulse, obtain a standard 5 pin Bosch automotive type relay* and wire as follows:-
Alarm's trunk release to 85
12V+ constant fused at 15 amps to 87 and 86
Cut the white wire, then fusebox end to 87a and
trunk end to 30.
Remember to also purchase a 1N4004 diode* and place in line to the relay with the band (cathode) away from the relay. See the diagram.
Sorry, ignore GWA on the diagram.
Posted By: mbsaudio
Date Posted: June 03, 2011 at 4:39 PM
Thanks guys. Audiovox doesn't list anythhing either. Car will be here tomorrow and I'll post the results. Will try to trace wire back from motor in trunk
Date Posted: June 03, 2011 at 5:11 PM
AudioVox lists this for a 2007 Yaris:
Trunk Trigger LIGHT BLUE (-) AT LEFT SIDE OF FUSE BOX 30 PIN PLUG PIN 7
I guess the link I posted before did not work.
Posted By: howie ll
Date Posted: June 03, 2011 at 5:14 PM
Oh oh, we've got two different answers from Audiovoxposted_image Could I suggest our poster gets out the DMM?
