04 pilot, keysense and factory alarm.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127869
Printed Date: April 26, 2026 at 11:29 AM
Topic: 04 pilot, keysense and factory alarm.
Posted By: skaman11
Subject: 04 pilot, keysense and factory alarm.
Date Posted: July 09, 2011 at 10:21 PM
Hey
I installed a Clifford RSX 3.5 into my 2004 honda pilot everything works fine except I have two problems. When I remote start it sets off the factory alarm(unless i unlock the car first). 2nd thing is that after remote start and the key is inserted in to the ignition the dome lights stay on unless I open the door and close it again. I do not have the keysense wire plugged and I am not even sure the module has one, I cant find anything about the keysense wire in the install Manuel.
I also don't have the H2 harness to wire up the factory disarm, is their a way of disarming that with out having to buy that harness?
As far as the key sense,and domelight any thoughts?
Thanks in advance!
Posted By: Velocity Motors
Date Posted: July 10, 2011 at 4:18 PM
Use the status output wire on the key sense and also program the remote start to unlock before start and relock after start for the OEM disarm feature.
Posted By: skaman11
Date Posted: July 10, 2011 at 9:01 PM
Easier said then done! . I am not really certain on how to program the RS to unlock, then start, then re-lock. I was looking over the install Manuel. So do I set programming option 2-10 to (3 chirps) and then turn on 2-14 channel linking to Arm?
Posted By: muaiad97
Date Posted: July 23, 2011 at 10:23 PM
for the interior light  u can program the unit to  ignition door lock option this will lock the doors and turn off the interior lights  and the sacand  to disarm the factory alarm  connect the disarm wire from the remote starter to unlock wire from remote starter together and lock wire withe arm wire  together  wil fix the problem
