03 silverado alarm install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12790
Printed Date: May 16, 2026 at 1:03 PM
Topic: 03 silverado alarm install
Posted By: Tinner7
Subject: 03 silverado alarm install
Date Posted: April 27, 2003 at 9:39 AM
hey all, I got a 03 chevy silverado without factory keyless, heck it doesn't even have powerlocks, well anyway I am installing a viper alarm in it in about a week, I was a installer for about 10 years, but have not installed anything in about 2 years :(   is there any factory security problems I may run into here? I am hoping since this is a stripped down stock truck, the install will be pretty straight forward, if not, any help would be great
Posted By: draasch
Date Posted: April 27, 2003 at 10:09 AM
well i dont have much on the truck yet, but here is what i have......
Constant 12 volts RED BEHIND FUSE BOX
Ignition 12 volts WHITE BEHIND FUSE BOX
Starter
Dome Light GRAY/BLACK (+) GRAY PLUG AT THE B.C.M.
Trunk Pin Switch
Parking Lamp GRAY/BLACK (-) AT LIGHT SWITCH
im not sure if you have a pass type of system in there. the OM might tell you..
post your findings if you dont mind.....
good luck,
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: Velocity Motors
Date Posted: April 27, 2003 at 4:29 PM
|              12V|red (x2)            |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink (12 awg)       |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|use Directed module |   |                            |
|     POWER UNLOCK|part #456G *2       |   |                            |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |pass. door module in door   |
| PARKING LIGHTS -|gray/black          |   |brown plug @ BCM *1         |
|     DOOR TRIGGER|gry/blk(L),blk/wht(R|-  |each door module in door *3 |
| DOME SUPERVISION|use door trigger    |   |                            |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|NOT pnk, blk, or brn|   |any ignition coil           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|pink                |-  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |driver window motor         |
|  RF WINDOW UP/DN|blue - brown        |A  |passenger window motor      |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. The passlock II wire colors are yellow, black, and RED / white (not used).  *1 The BCM (Body Control Module) is under the driver side dash.  *2 If Directed module part #456G is not available, refer to directfax document #1601.  On base model trucks the lock wire is lt. blue (-) and unlock wire is white (-). They are in the lt. blue plug at the BCM.  *3 On base model trucks the door trigger wires are in the lt. blue plug at the BCM. On 4dr trucks the LR door trigger is lt. blue/black, and the RR is lt. GREEN/ black. They are in the purple plug at the BCM. Use all wires and diode isolate.
