bulldog r/s in 2011 fusion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128057
Printed Date: April 28, 2026 at 9:11 PM
Topic: bulldog r/s in 2011 fusion
Posted By: je3169
Subject: bulldog r/s in 2011 fusion
Date Posted: July 27, 2011 at 5:14 AM
Hay all I am Installing a bulldog R/S into a 2011 fusion have it all installed and want to hook it up with the factorykey fob I have tested the blue wire from the R/S and it takes 3 - pulses I tryed the blue /green wire at the drivers side kick panel but it will not work with the key fob ( if i hit the door lock button I get a pulse but if I hit the key fob I get nothing)anybody know what wire I can tap on to + or -
Thanks John
Posted By: kreg357
Date Posted: July 27, 2011 at 6:24 AM
Try using the Lock Motor wire.  It should be in the same DKP area.
Lock Motor      Gray/Brown       driver kick or SJB, black 32 pin plug (D), pin 6
Put a DMM on it to verify you have the right wire.
Posted By: je3169
Date Posted: July 27, 2011 at 6:52 AM
Thanks for the help
John
Posted By: je3169
Date Posted: July 27, 2011 at 3:37 PM
UPDATE not sure if anyone elas is having problems finding the Lock Motor      Gray/Brown       driver kick or SJB, black 32 pin plug (D), pin 6
like me I went to the driver side back door gray/black you can pick it up at the post right behind the drivers door it is 12 volts + and then just have to use a relay if you need a -
John
Posted By: kreg357
Date Posted: July 27, 2011 at 7:22 PM
Excellent, thanks for that good info and update!
