2005 honda odyssey sliding door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128526
Printed Date: April 11, 2026 at 11:00 AM
Topic: 2005 honda odyssey sliding door
Posted By: tianot
Subject: 2005 honda odyssey sliding door
Date Posted: September 14, 2011 at 2:20 PM
im installing a compustar cm5200 unit and use the idatalink ads-al bypass module. base on the installation guide of ads- al for the the odyssey, how can i pulse the sliding door if i use a d2d connection. if i use the d2d connection the bypass will take care everything from doors to sliding door. how can i activate it to the cm5200 unit? thanks
tianot
Posted By: tonanzith
Date Posted: September 14, 2011 at 9:08 PM
The alarm still has functionality from its auxiliary output features even though it is connected to the idatalink module so you can use those.
Gary Sather
