2001 dodge caravan, prostart 5010
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128531
Printed Date: April 11, 2026 at 12:54 PM
Topic: 2001 dodge caravan, prostart 5010
Posted By: stewfire
Subject: 2001 dodge caravan, prostart 5010
Date Posted: September 15, 2011 at 9:40 AM
I have a 2001 dodge caravan and I am installing a prostart 5010. Everything is hooked up and the starter works will but when I put the key in the ignition and trun it to the run position the van try's to start without me turning it to the crank position what did I do wrong. I also have power to the starter wire all the time can anyone help thanks
Posted By: Twelvoltz
Date Posted: September 18, 2011 at 9:31 PM
The 01 Caravan has 2 starter wires, one is a standard positive trigger the other is a ground through 180ohm resistor. How did you wire the relay for the second starter wire? Also, post back what you have tried during your troubleshooting already.
