low or no tach signal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129086
Printed Date: April 04, 2026 at 12:09 PM
Topic: low or no tach signal
Posted By: longfoot
Subject: low or no tach signal
Date Posted: November 03, 2011 at 8:24 PM
i installed a viper remote starter about a year ago and all of a sudden it stopped working checked all wires all seem to be fine tried some reprogramming but to no avail didnt work so i was wondering if anyone had any ideas someone told me to change tach wire to fuel injector wire but i dont know if i can do that.
------------- buick1971
Posted By: longfoot
Date Posted: November 03, 2011 at 8:28 PM
the car is a 2000 pontaic grand am gt if that helps
Posted By: racerjames76
Date Posted: November 04, 2011 at 12:57 PM
3.1l or 3.4l I bet...Either they didnt solder the connection under the hood, and water has gotten in and corroded the connection, or your coil is going bad. Did you take the tape off and look at the point of connection? If it is bad new wire may need to be spliced in, including cutting part of the factory coil wire as well. Not reccomended for a beginner!
------------- To master and control electricity is perfection. *evil laugh*
Posted By: longfoot
Date Posted: November 04, 2011 at 3:11 PM
i did take tape off and no corrosion can i hook this wire to fuel injector wire?
Posted By: longfoot
Date Posted: November 08, 2011 at 5:20 AM
k if anyone runs into this problem dont chane coil check bypass that was my problem
