08 civic and remote start avital 4103
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129101
Printed Date: April 05, 2026 at 1:52 PM
Topic: 08 civic and remote start avital 4103
Posted By: wyciwug
Subject: 08 civic and remote start avital 4103
Date Posted: November 05, 2011 at 12:41 PM
completed the installation with DBALL. However, I keep getting LED flashes 4 times: remote control shutdown.
can will crank but not start. It only starts with key in ignition.
When i tried to learn tach, follow the manual but the LED will not come on while HOLD the switch down within 5 seconds of started the car.
What could be the problem?
I connect the purple white to ignition coil's wire: BLACK/ white.
Help please.
DCD
Posted By: triniforever
Date Posted: November 05, 2011 at 3:01 PM
Thats not the right tach wire in that car,you can use any wire thats Not BLACK/ white,black or yellow/black,any ignition coil or fuel injector wire
triniforever
