problems with viper 5701 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129178
Printed Date: April 07, 2026 at 6:44 PM
Topic: problems with viper 5701 remote start
Posted By: manny661
Subject: problems with viper 5701 remote start
Date Posted: November 10, 2011 at 8:16 PM
I'm having problems with the remote start on the Viper 5701 in my 2000 Honda Civic Dx (Manual Trans.) that i installed myself everything works excepts the remote start when i try turning it on i get 7 flashes & a error on the flash button from the remote which says it means (Manual Trans. mode is enabled and not initialized) I've tried going through the steps for the manual trans. but i still get an error on the remote at first it would work and I'd take out the key and the engine will stay running till i arm it but it would never crank or start when i remote start it, but now i cant even get it to that stage i just get an error on the remote here are the connections
Remote Start Harness -- Car
1.Pink (+)Ignition 1 Input/output -- Ignition(BLACK / YELLOW)
2.RED / White (30a)Fused Ignition/Flex Relay Input 87 -- Constant 12V
(White)
3.Orange Accessory Output -- Accessory(Yellow(+))
4.Violet (+)Starter Output(Car Side Of Starter Kill Wire) -- Starter(BLACK/ White)
5.Green (+)Starter Input (Key Side Of The Starter Kill Wire) -- Starter(BLACK/ White)
6.Red (+)Fused(30a)Ignition 1 Input -- Constant 12V(White)
7.Pink/White (+)Ignition2/Flex Relay Output -- Ignition2(WHITE/ Black)
8.Pink/Black Flex Relay Input 87A Key Side(if required) of Flex Relay -- N/C
9.RED / Black Fused (30A)Accessory)Starter Input -- Constant 12V(White)
10.N/C
Remote Start Output only one connected Violet(-)200mA Starter Output to negative cable on clutch .
Posted By: kreg357
Date Posted: November 10, 2011 at 9:20 PM
Here are a few things to check, as listed in the Viper install guide.
• Remote start MTS mode failure The remote emits a failure notification when trying to enable the manual transmission mode or the vehicle fails to stay remote started when the key is turned off.
Possible causes are: • Hood Open (gray wire). • Foot Brake active (brown wire). • No Parking Brake input, BLACK/ white neutral safety wire not showing ground with parking brake set. • Tachometer is not hooked up or programmed. • The unit has not been programmed for tachometer mode. • Toggle switch not installed or not in the ON position.
------------- Soldering is fun!
Posted By: smokeman1
Date Posted: November 10, 2011 at 9:37 PM
BLACK/ WHITE Neutral safety switch input
Connect this wire to a ground source if installing this unit in an automatic transmission vehicle. If this unit is being installed in a manual transmission vehicle then connect it to the emergency brake wire. This input MUST rest at ground in order for the remote start system to operate.
From page 45 of the Install Manual ------------- When all else fails, Read the Instructions
Posted By: manny661
Date Posted: November 10, 2011 at 10:31 PM
Yeah i got all of them hooked up but ill be sure to double check them thanks
Posted By: manny661
Date Posted: November 10, 2011 at 10:42 PM
Yeah i hooked up the Blk/Wht to the emergency brake, but i dont understand why its not letting me enable it to mts mode when it was working only once though but it wouldn't start or crank after trying to start it with the remote now its just giving me 7 flashes and error on flash
Date Posted: November 11, 2011 at 3:59 PM
Assuming that all needed wires are attached correctly, door triggers, Hood pin, Brake, ect, I would try unplugging the heavy gauge harness and the H1 harness from the module for 10-15-30 minuets and see if that might clear anything. Plug them back in and see what happens. make sure the unit is in the manual transmission mode.
Posted By: manny661
Date Posted: November 12, 2011 at 7:54 PM
Okay double checked everything and unplugged harness 1 and plugged it back the only thing i found wrong was the brake switch was on the negative instead of positive remote start still doesn't work though, but can it be that VIOLET cable from the remote start output MUST be hooked up to a SPDT relay to bypass the clutch cause i only have it connected to the clutch cable?
Posted By: kreg357
Date Posted: November 12, 2011 at 8:04 PM
Try a remote start while you depress the clutch pedal. ( Stay in the car after you set reservation mode. )
Posted By: manny661
Date Posted: November 12, 2011 at 8:12 PM
Okay just tried it still got the error flash on remote and 7 flashes on car, can it be that i might need the SPDT relay or bypass module ?
