viper 5900
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129288
Printed Date: April 08, 2026 at 10:25 PM
Topic: viper 5900
Posted By: forged71
Subject: viper 5900
Date Posted: November 19, 2011 at 12:08 PM
I have installed the alarm following the guides and wire diagram problem is my door trigger wire according to the diagram is a negative trigger and the viper harness say its the green wire from the H1 harness however my door open dash light glows when doors are shut and gets bright when they are open...any thoughts???
Trial And Error!
Posted By: forged71
Date Posted: November 19, 2011 at 1:37 PM
Might add that it's installed in a protege5 I'm pretty sure it's wired right. Any help would be great.
Trial And Error!
Posted By: howie ll
Date Posted: November 19, 2011 at 1:46 PM
Use a DEI DTI* Mazda converter your door switches are opposite to normal, i.e. ground on shut, go open circuit when the doors are opened.
Or check the programming you might be able to program for it.
Posted By: forged71
Date Posted: November 19, 2011 at 3:50 PM
Ok I've tried searching for the dei tdi Mazda converter but nothing shows do you by chance know where I can find one?
Trial And Error!
Posted By: howie ll
Date Posted: November 19, 2011 at 5:36 PM
What year is your Mazda?
Posted By: forged71
Date Posted: November 19, 2011 at 6:00 PM
It's a 2003 protege5..
Trial And Error!
Posted By: howie ll
Date Posted: November 19, 2011 at 6:09 PM
Did you connect the 5900 green door trigger wire to a BLACK/ blue in the driver kickwell?
Incidentally it's Trial AND Error.
When I see unchecked typos like that I always worry about the install quality.
Posted By: forged71
Date Posted: November 19, 2011 at 9:17 PM
Yes I did.
Trial And Error!
