| Print Page | Close Window |
07 chevy silverado classic viper vss300Printed From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129382 Printed Date: April 12, 2026 at 6:07 AM Topic: 07 chevy silverado classic viper vss300 Posted By: rwb713 Subject: 07 chevy silverado classic viper vss300 Date Posted: November 25, 2011 at 4:57 PM Hey guys, Complete newbie to this forum (sorry :( , i hate it too ) but i purchased a viper vss3000 remote start kit w/ dsm200 smartstart recently and i'm looking for info before i start the install. I've browsed around the forum and seen a few things that could help, but i want to get a few more opinions and some info before i dig in. I have a decent knowledge of DC electronics, know how to use a multimeter, and have worked for years with simpler vehicle electrical installs, troubleshooting, and the like. This remote start is a little more in depth than i've been into tho, mainly because of the actual involvement of the BCM/PCM of my truck. First off, does anyone have the wiring diagram for an 07 Silverado Classic, and/or is it just the same as an 06? Second,. What other modules do i need (and where do i get them) to get it to work correctly? and if possible, why i need them would be great info. My truck has power locks / windows, and keyless entry (LS Package), which i want to be able to lock/ unlock with the smartstart as well. Third, Suggestions? Comments? Trash Talk? Useless info? All is welcome. Thanks in advance Replies: Posted By: silverbullet555 Date Posted: November 25, 2011 at 9:56 PM I just finished installing a Viper 5702 in a 2007 Silverado Classic. For the wiring I used the 06 wiring diagram and it was a perfect match. I used a DEI DLPKGM bypass module and hooked it up D2D. All features worked.
I prewired the alarm and module and then did the install in the truck. ------------- James Posted By: rwb713 Date Posted: November 26, 2011 at 11:42 AM Do i need a seperate module for the door locks too? I read something about some models needing them and some not, but the post was really unclear
Posted By: rwb713 Date Posted: November 26, 2011 at 11:55 AM Further research shows i can use a combo bypass module for both start & locks. Anyone used the Xpresskit DBALL? Does it work as good as it seems like it should? Posted By: zerepdivad Date Posted: November 27, 2011 at 12:32 AM Extremely easy truck to do. DBALL will work just fine on that truck and should take care of everything.
Item Wire Color Polarity Wire Location 12 Volts red (40A) + ignition harness Second 12 Volts red (40A) + ignition harness Starter yellow + ignition harness Second Starter N/A Ignition pink + ignition harness Second Ignition white + ignition harness To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system. Third Ignition N/A Accessory orange + ignition harness Second Accessory brown + ignition harness Third Accessory N/A Keysense lt. green - BCM, lt. blue plug, pin A1 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Data Bus yellow (resistor code), black (ground) Passlock 2 Passlock sensor on ignition key cylinder Can Bus High N/A Can Bus Low N/A Can Bus Sw purple (J1850 Class 2 Serial Data) data data link connector, black 16 pin plug, pin 2 Power Lock use Directed interface module (except base models) If interface module is not available, refer to Tech Doc 1601. The driver door lock/unlock motor wires are gray - tan (5 wire) at the driver window switch, black 26 pin plug, pins 21 and 20. The passenger door lock/unlock motor wires are gray - tan (5 wire) at the passenger window switch, black 26 pin plug, pins 10 and 11. The rear doors power lock/unlock wires are gray/black (-) - tan/black (-) at the BCM, gray plug, pins A6 and A3. The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. ON BASE MODELS, THE POWER LOCK - UNLOCK WIRES ARE LT. BLUE - WHITE (-) AT THE BCM, LT. BLUE PLUG, PINS B5 and B10. Power Unlock see power lock Lock Motor gray (except base models) 5 wire driver window switch, black 26 pin plug, pin 21 On base models, it is gray (5 wire) at the dash fuse box, black 12 pin plug, pin C. Driver Unlock Motor tan (except base models) 5 wire driver window switch, black 26 pin plug, pin 20 On base models, it is tan (5 wire) at the dash fuse box, black 12 pin plug, pin F. Passenger Unlock Motor tan (except base models) 5 wire passenger window switch, black 26 pin plug, pin 11 On base models, it is tan (5 wire) at the dash fuse box, rear, black 68 pin plug, pin D11. Parking Lights (-) gray/black - BCM, brown plug, pin B2 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Parking Lights (+) brown (L), BROWN / white (R) + underhood fuse box, red 32 pin plug, pins F6 and C6 Hazards white - hazard switch Turn Signal (Left) dk. green + turn signal switch Turn Signal (Right) lt. green + turn signal switch Headlight white - BCM, lt. blue plug, pin A12 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. AutoLights dk. green (ground to turn off autolights) - BCM, brown plug, pin A8 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Reverse Light lt. green + BCM, black plug, pin F The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Left Front Door Trigger gray/black (except base models) - driver window switch, black 26 pin plug, pin 18 On base models, it is gray/black (-) at the BCM, lt. blue plug, pin B4. The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Right Front Door Trigger BLACK/ white (except base models) - passenger window switch, black 26 pin plug, pin 5 On base models, it is BLACK/ white (-) at the BCM, lt. blue plug, pin A5. The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Left Rear Door Trigger lt. blue/black - BCM, purple plug, pin A3 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Right Rear Door Trigger lt. GREEN/ black - BCM, purple plug, pin A2 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Dome Supervision gray/black + BCM, black plug, pin E The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Trunk/Hatch Pin N/A Rear Glass Pin N/A Hood Pin N/A Trunk/Hatch Release N/A Trunk Release Motor N/A Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm arms on lock with door open Factory Alarm Disarm lt. green (driver door key cylinder) - driver window switch, black 26 pin plug, pin 15 Disarm No Unlock see factory alarm disarm Trunk Alarm Shunt N/A Tachometer white ac instrument cluster, gray 24 pin plug, pin A5 Can also go to the PCM (Powertrain Control Module) in the left front of the engine compartment to the left of the fan shroud. On gas models, the tach wire is in the green plug, pin 10. On diesel models, the tach wire is in the black 58 pin plug, pin 55. On hybrid models, the tach wire is in the green plug, pin 35. Wait to Start dk. blue - instrument cluster, gray 24 pin plug, pin A2 Can also go to the PCM (Powertrain Control Module) in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the black 58 pin plug, pin 16. On the remote start, make sure to program the Accessory State During Wait To Start to ON. Neutral Safety N/A Clutch Pedal pink (input), dk. green (output) +N.O.(gas) clutch switch, black 6 pin plug, pins C and D On diesel models, it is - N.O. Fuel Pump gray + underhood fuse box, red 32 pin plug, pin F1 Rear Defroster white - latched BCM, gray plug, pin A8 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Mirror Defroster (Class 2 Serial Data) Left Front Heated Seat dk. blue + driver window switch, green 12 pin plug, pin 9 Right Front Heated Seat dk. blue + passenger window switch, green 12 pin plug, pin 3 Speed Sense dk. GREEN / WHITE 4K instrument cluster, gray 24 pin plug, pin A4 Can also go to the PCM (Powertrain Control Module) in the left front of the engine compartment to the left of the fan shroud. On gas models, the VSS wire is in the green plug, pin 50. On diesel models, the VSS wire is in the black 58 pin plug, pin 42. Also found at the radio harness, on some models. Brake Wire white + brake switch Parking Brake lt. blue - BCM, lt. blue plug, pin A7 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Horn Trigger black - BCM, gray plug, pin B9 The BCM (Body Control Module) is under the driver dash. It has 6 plugs, the purple plug is on the back. Wipers pink (L), dk. blue/white (H), yellow (ignition) +,- wiper switch Left Front Window (Up/Down) dk. blue - brown C driver window switch, black 4 pin plug, pins 3 and 1 Right Front Window (Up/Down) dk. blue - brown C passenger window switch, black 4 pin plug, pins 4 and 1 Left Rear Window (Up/Down) dk. blue - brown C left rear window switch, brown 8 pin plug, pins F and G Right Rear Window (Up/Down) dk. blue - brown C right rear window switch, brown 8 pin plug, pins F and G Sun Roof (Open/Close) brown - orange (function with ignition on only) + sunroof switch, black 8 pin plug, pins E and A Sun Roof (Limit/Close) N/A Memory Seat 1 red + driver window switch, green 12 pin plug, pin 10 Memory Seat 2 pink + driver window switch, green 12 pin plug, pin 5 ------------- A DMM is a beautiful thing. MECP Advanced Installer Certified. Posted By: rwb713 Date Posted: November 29, 2011 at 5:52 PM Thanks a bunch!, just ordered the DBALL and the xloader2 which should be here friday, I'll get it all put in next week and let ya know if i catch anything on fire. (that's entirely sarcastic, i don't see myself having any problems at all really). Anyone heard anything about the Viper smartstart carrier not being able to handle the amounts of traffic it gets?
